You can have a NAS running “blind”, it does require some preparation though.
Easiest way to achieve it is to put in a temporary graphics card while you install the system, and then remove the card and log in through SSH when you are done with the base install. It’s also possible to install the OS to a drive and install said drive in the NAS.
