Want a new monitor plz help :D
Alright so I'm gaming on a tv, but I want to get a good monitor because this tv isn't great for gaming. I'm looking for a great monitor (or the best I can get) for under $200. Any suggestions?
If you want the best possible response time, which between 1 - 5ms is typically negligible, go with this:
http://www.amazon.com/VN247H-P-24-Inch-Screen-LED-Lit-Monitor/dp/B00AVYNS7M/ref=sr_1_1?ie=UTF8&qid=1388636312&sr=8-1&keywords=VN247HP
If you'd like something between good viewing angles, color and response time:
http://www.bestbuy.com/site/23-ips-led-hd-monitor/8176078.p?id=1218864997552&skuId=8176078&st=aoc%20monitor&cp=1&lp=2
The AOC also comes with an included DVI to HDMI cable.
If you have the hardware to power it, you can get a 1440p monitor for $300. Check out the crossover 27qw. Got it about two months ago. Runs fine looks fantastic and so much better than my previous 1080p monitor.
Anyways, if only capable of under $200, I would not bother unless your current screen broke and you simply needed a new screen and did not have the money for the  crossover.
