Wallmount Dell Monitor U2713HMt - Issue so stupid - you won't belive
So I wanted to hang my LCD screen on the wall. Went to the shop and bought one looknin strong. It's heavy and nothing made me suspicious, but it happend... while mouting it on the wall I was acctually surprised by its quality, but mouting handle lcd side - hell started. I was doing it by hand, with a screwdriver, but non the less two screws just broke off in half, leaving their leftovers inside the screen holes, in such a manner, they can't be unscrewed with any tools I have in my posession. I have a spare pack of "unscrew broken bolts' drilling bits, and my GSB, look pictures.
Do any1 of you had something like that in the past and can share opinions? I can't afford sending it anywhere, so have to make a solution here by myself. I want to dissasebmle the back cover - but how to do it? I don't see any screws, I think it's made on a "CLICK" and I'd have to pull up something. Could any1 point me places where to start here?
Photos included
Never seen that before, never wall mounted a monitor before. But I have broken many, many screws in many things.
Does the bolt/screw extractor you included not work?
it did not. I ended up disassembling the whole monitor, now I'm at the core of the electronic, which I have to take out in order to remove original holes for screws, and I will use long threaded bolts which I will secure with.... eh, I want it to look like here, they've got same issues :
Ok so problem solved. I made a lot of photos so will pastem them here in sort of a 'solving please god no please situation' tutorial :)
nvm.. but it seams a lot of hassle to get that thing right XD
