Anyone else waiting for Threadripper 5000? Rumors point to August <-> November timeframe, so I’m still stuck with an underpowered rig, optimizing my (hopefully soon) purchases.
While testdriving my future distros in my grandma-class 4core+8GB machine, I’m getting tired of swap getting filled on my very rusty 3.5" HDD.
So I might as well post my shopping list for you to criticize or improve
CPU: Threadripper 5000 32 Cores (probably called 5970x?)
Mainboard: Gigabyte TRX40 Designare
Memory: 128GB Kingston ECC DDR4-3200 CL22 or non-ECC G.Skill to save 100-200$
GPU: GTX770 (host), RTX 2060(guest) both from my old rig until GPU prices behave themselves. Aiming for new 3080ish card in early-mid '22.
I have three 32GB DIMMs of those and they are good. I mostly have them because I use ZFS and are paranoid about my data integrity. As long as you don’t handle mission critical data you can also use regular DIMMs. I have read that memory errors have become much less frequent, than they have been years ago, so if you handle non critical data you should be fine.
What also comes to mind is make sure the mainboard has good IOMMU groups, in case you plan to do virtualization with passthrough. I am not familiar with Threadripper class mainboards and can’t give you information on those.
Otherwise this looks like a really nice machine. Which distributions are you testing out, maybe we can give you some input on those.
Kingston Ram is 4x 32GB sticks. I was really surprised to find those for reasonable pricing at my go-to store. Didn’t expect to get 3200 ECC because ECC memory tends to be lower clock speeds most of the time. Also seen reviews of them running very stable at 3600MT/s CL20 after long stress test. Seems very good quality and feature package as far as I can see.
Machine will be my main PC I use for everything from gaming, editing,encoding, some CUDA stuff, access to Win+MacOS and running servers in VMs for personal cloud services. I expect this machine to run most of the time as I want to cover most if not all bases at once. Passthrough and IOMMU will be a thing for me.
Distros I’m currently looking into PoP OS, Arch and Arch/Garuda for my host and some more specialized Distros as well as Win10Pro for guests. With advancements in file systems, I’m getting myself up-to-date with modern approaches like BTRFS and ZFS that weren’t so common for consumers when I last put work into Unixoid OSes.
Distro choice for me is more to be a smooth transition from Win desktop-wise while still offering all the open source tools necessary for the job. I’m really impressed by productivity gains from todays KDE/Gnome features and terminals customizations, even after only a couple of hours in.
I heard the same! I have not tried to overclock mine, though. You have to test them conscientious, since the error correction might otherwise mask instabilities and compromise the DIMMs data safety. If you overclock you have to look out for single bit errors, because when you provoke them, by to much overclocking, you are bound for unrecoverable 2 bit errors. The price I paid was also very similar to regular DIMMs.
Then please check if the Designare’s IOMMU groups are good in advance. I would suspect as much of a high performance platform, but still I would make sure.
Both are fine. Arch is quite a bit more work to setup. Also you have to decide if a stable release or bleeding-edge distribution are better for your use cases. In general one can work with both perfectly fine.
Both definitely nice filesystem. I am more familiar with ZFS and it has a little learning curve. since it has so much more features than a regular filesystem.
I am waiting too. At this point, I would have least expected an announcement for the announcement to come out by now. XD But no such luck.
Not sure what my hardware is going to look like, but I’ll have a ton of RAM and if I can get my hands on one, I’m going to do the 6900XT for my gaming VM. The motherboard will need to have IPMI for sure. ECC memory since I’ll be doing storage on it. Might do a custom loop, but I don’t know, we’ll see, the ProSiphon looks good enough.
As for software, I’ll be doing Unraid as the base, will have a bunch of dockers and then a Windows VM, a Linux VM, and an EVE-NG VM for doing my networking labs (this will be using most of my RAM).
Rather silent on AMDs side atm. But with the new Ryzen APUs and the 6600XT released, there isn’t really much else other than Threadripper that is expected this year, so we might be lucky soon. Has been almost 2 years since 3000 series launched, we need more power NOW!
I just like to get rid of high maintenance and moving parts, so no liquid cooling and SSD only…just clean the filters and get the vacuum cleaner going every couple of months. I rather get decent air cooling and get some extra stuff instead of spending 500$ on a custom loop. I see the point with 2x or 3x GPU, but 1x CPU+1xGPU…watercooling is mostly about the looks when you have things like the ProSiphon Elite as a (much cheaper) alternative. 2x 360mm radiators are 6 fans too…so noise isn’t that different either.
With HDDs, I’d go striped mirror (RAID10 or equivalent, depending on file system) without hesitation. But NVMe storage isn’t cheap, so I’m somewhat negative on dropping storage efficiency to half and mirroring is double the writes (draining health off two drives at once, so bad for SSD health) anyway.
I got a spare external HDD with 8TB, and incremental backups, even as basic as rsync, will do the job for a long time. So there is no “Game Over screen” even when using ext+LVM.
I heard bad things about ZFS and Linux kernel (would love to use it though, the Sun nerd in me alone would), so I’m still split in choice between BTRFS and ext4+LVM. BTRFS has snapshots, and LVM has some nice resize features.
I didn’t check disk benchmarks on whether striping across 4x NVMe does any good/bad to performance or SSD longevity, but I’m not dependent on 10GB/s sequential reads and value latency and IOPS way more. So striping isn’t really necessary to me, but some partitions for swap or e.g. large apps/games/videos might see some real world benefits.
That’s neat. I didn’t know or imagine to format logical volumes with btrfs to then create subvolumes. That’s some expert advice right there. Best of both worlds
btrfs gets you everything out of the box except crypto and tiered storage. You can also shrink filesystems and add/remove underlying storage to change raid levels on the fly.
You can’t mix raid levels between subvolumes either, but if you do it on top of LVM you can maybe mess around and build a btrfs filesystem per raid config.
I am interested what you have heard. ZFS is stable enough for enterprise environments. It is certainly a rabbit hole and has a learning curve, but it is a awesome filesystem. There are even some guides out there to install certain distributions on a ZFS filesystem directly ( root on ZFS ). The only downside here is that most distributions don’t include it in the installer because of the incompatible licensing. BTRFS is another great filesystem with many advantages and some downsides that is however included in every major distributions installer.
Mostly comes down to native support issues I have as migrant as well as the learning curve you mentioned earlier. There are only so much chunks I can chew at a time. So I’ll probably save ZFS for later. Got some NAS planned after my budget recovers a bit in early '22.
And RAM prices are volatile atm…I wish I could buy the system now and get the CPU later, but TRX40 CPUs aren’t the “oh just get a cheap one for a couple of months” kind. AM4 I could get a Ryzen1200x or Athlon for 60 bucks, build the system and upgrade the fancy nextgen CPU later.
But cheapest TRX40 is around 1.5k EUR.
Really sad when got the money and really want to buy your next dream system but one critical component is still lacking. I can understand the GPU shortage and desperate gamers so good now although I’m not GPU-starved but CPU-starved.
Waiting for TR5000 continues…so many ideas, so much passion, but still: so Level1.
