Note: for the psu, im getting a local company's 650 watt 80+ platinum psu, not the one listed.
I'm not exactly sure that should I wait or not. My original thoughts were that I'll wait for an extra year or two for generation 2 or 3 haswells to come out since they'll be more stable. But now I'm thinking, if i save for three more months, I'll get a higher budget and buy an even better computer.
Don't wait for anything lol. New shit ALWAYS will be coming out. No point waiting unless it's like a week before haha. If you want future compatibility you could get an 8350 since they're staying on AM-3 for a while. At least I think it's AM3 i forget. Either way, the next series will be on the same socket. What do you need 2 monitors for? If it's for editting, I vote nvidia card. If it's just so you can see what's up on Facebook etc while gaming, you're all good. BUT, maybe 16gb of ram could be better for that? Idk. I'd get 2x4gb. Then you still have an upgrade path to 16gb. Could remove the SSD and get a 7970. I'd grab a 7870XT if you aren't willing to do that since they're super cheap atm. Get the sapphire one though! You don't NEED a higher budget. That's perfectly fine.
But my suggestions, drop the ssd, switch to AMD, and get a 7970. Intel is fine, just no future with 1155.
