Wait for GTX 960Ti?
Hey guys im planning on upgrading my gpu to meet current demands. My budget (RM900/200$) only allows me to get a GTX 960. But recently run into some rumours about the new GTX 960ti releasing soon. What should I do? Or should I just get a r9 280x. I just wanna max out Fallout 4 at 1080p60fps. Hope you nice guys can help. Cheers
A 280X would do just fine, if you really want to be paitent waiting fr the 960Ti might be a good idea.
Honestly there's two things you can do.
there is an R9-390 4GiB model that's coming soon it will be less than $300. or if you wish to have something now I recommend the R9-380x. which blows the 960 out of the water.
For the $200 budget, that could be great. I usually tell people with that kind of budget to get refurb/open box sales or the sort to get more bang of the buck. On amazon you can find the 280/380 for at or under $200
