Wait for FM2+ or go for AM3+?
So I built a kill my console PC last year/early this year (was a ongoing project), I had done previous PCs for my family but they were never really good spec or particuarly "custom". I chose the A10 5800k with 6670 dual graphics as recommended by many for my reasonably low budget.
I've recently bought a new graphics card (7870GHz Ed.) and I've noticed I have noticed what seems to be quite a large CPU bottleneck in quite a few games (at least I think it's a CPU bottleneck, CPU @ 100% GPU sitting around 60% and it's not running too smooth)- this is at 4.6GHz and "stable". And these aren't games that are considered by most "CPU bound" bar GTAIV.
So I was thinking of upgrading my machine late this year or early next year and I have a bit of a dilemma; should I go to AM3+ with a FX8350 or shall I wait for Kaveri to land on Desktops?
AM3+ has the power advantage, but can the steamroller chips and the potential discontinuation of the FX line make it a smarter buying choice to invest in a FM2+ board with its better feature set? I see a lot of nicer FM2+ boards coming out than AM3+ revisions, could this mean FM2+ is going to be AMDs only desktop socket?
Will be interested to see what other people and potentially the guys at Tek Syndicate HQ (or whatever you call yourselves!) think would be best, thanks!
if anything AMD's HSA (heterogeneous system architecture) will come out eventually, maybe wait for that?
I did think about that; but will I be able to use it having a dedicated discrete GPU rather than relying on the integrated gcn cores?
maybe if it was a amd gpu. but not really sure how it's all gona work. i doubt PCI express has enough bandwidth. i think the ps4 is using HSA because of the shared memory.
I believe so. The point of HSA, last I saw, is to have simple programs run on the CPU and to have more complex programs run on the integrated GPU because the integrated GPU has more power than the CPU
EDIT: Clarification
The FM series is designed to use a CPU and an iGPU anyway. You would get more power out of using AM3+ I would think.
The AM3+ CPU's (6 and 8 core ones) are definitely going to be better for gaming than the Kaveri's will since they'll only be 4 cores at best. Discussing about future products for AM3+ and for FM2+ after Kaveri is pointless since AMD hasn't confirmed either, although there's multiple hints at AM3+ getting more cpu's in the future.
