VPN, bittorrent, firewall problem
I chose to use Anonine VPN and as far as I can tell it is just as fast as my internet connection when torrenting with speeds of up to 2.0 mb/s. I am loving it so far.
So now I'm trying to make things more secure by using my Comodo firewall and setting up a rule for uTorrent where if my VPN disconnects, then my regular LAN network adapter will be restricted from being used by uTorrent. I set this rule for Chrome and it worked when I disconnected my VPN. But when I try it with uTorrent, initially it looked like it worked where I thought it killed the download but then the D/L speeds were crawling back up as if It was using my real IP address. I don't know what to do. Can anyone help me here?
Here's a picture of my application rule:
[url=http://postimage.org/image/3neu9d1xz/][img]http://s15.postimage.org/3neu9d1xz/Untitled.jpg[/img][/url]
Thanks
EDIT: By the way, I'm a noob when it comes to configuring firewalls. I just want to know how to configure my Comodo firewall from blocking my internet connection in case my VPN connection drops so that my IP address does not leak.
