Is this something that windows just does better/ more simply?
Every time we need to expand a disk/volume in a linux vm (Ubuntu Server most of the time), it usually requires us to reboot it first, after extending the disk in vsphere. Then we can go through Parted and resize2fs.
Is there a straight forward way to do this online like you can with disk manager in windows?
There’s no real reason for rebooting a vm, usually.
For linux-dists, one might have to perform a rescan; echo 1 > /sys/class/block/sd[x]/device/rescan
I’ve not yet seen anything so old that a reboot is needed. If I am in the wrong, please do give some details if possible of your versions etc.
LVM does not aid in this at all as per my experience - it’s simply a logical volume, but under it it’s still drives. However, if you are running LVM, you can ofc just add a disk, and then go through the motions to add it to the volume, and then expand the underlying filesystem.
Well, that’s a don’t without a reason - in short, I would think that sg3-utils performs the same thing.
Either way, I’ll continue to do this without additional tool set that results in the same thing.
Sure, it can cause issues if you don’t know what you’re doing. However, flipping a scan-flag is not causing havoc.
To know that a program is mature, and correctly programmed - I’d need to validate the program and source - while typing it straight into the prompt, I have already validated what I have asked to be performed.
