This is my first time posting. I have just done a PC build, and I am trying to do this pass through so i can run my engineering apps, AutoCAD, Solidworks, Allen Bradley Automation. I have an i5 -4690k 3.5 LGA1150 ASUS Z97-A DDR3 2600 MB ASUS STRIX GeForce GTX960 4GBDDR5
i am running Debian Jessie 8.2 with Gnome, and the newest version of virtual box. Can i have a step by step guide cause There is just so many things to scour through. I really want to do this and i have the skill and help but having just one packet of info for my situation would be a great way to get me started.
I'd be interested in hearing if you got this to work. I played around with the idea of doing a GPU passthrough a couple months back but I was also trying unsuccessfully to do so through VirtualBox. I might give KVM a shot soon.
I believe it was puget systems which has a quite good guide of how to. They use Qemu as the VM, It worked somewhat for me, but be prepared for Nvidia being absolute dick holes when it comes the implementation of their drivers in your OS. Basically i had an APU, and it worked "somewhat" well with that as the passthrough hardware(Basically you dont wanna run a on chip gpu for this), but the NVidia GPU simply wouldn't release. And anytime i tried any solution it just threw me into an emergency console on reboot, albeit i used ubuntu to try it out. You won't get it running through Virtual box, they kind of use a different technology for passthrough of hardware, kind of just redirecting it into a VM, not really releasing it from the OS, and allow access to the "shared" memory addresses.
