Love the idea of running windows with hardware pass though. However I know the Phenom cpu is not capable of that type of virtual capabilities. I guess my question is is there a way to do a linux vm in linux that would give you hardware pass though? That way I could mess with wine and other things without breaking my host system and still have actual hardware do the work without the vm middle man? Thanks.
Running Opensuse. May do a fresh install so i can undo all the bad things I did in the beginning.
I have a 890fx motherboard. From what I have read AMD requires all cpu features to be available on chipsets that support the cpus. So My motherboard does support AMD-Vi which is a FX processor feature not a Phenom feature. So if the 1090T does support AMD-V I should be able to activate that in the bios then
The Phenom is totally capable of IOMMU, not on all SKU's, but on most. All AMD mobos are capable of IOMMU, because it's an AMD requirement to OEM's that they implement all the features the chipset offers. Some OEM's, mainly Asus, make it difficult by reversing "yes/no" in the BIOS settings or by trying to withhold users from using an IOMMU enabling BIOS by classifying the IOMMU capable BIOS as "beta", but that should stop nobody...
