Visual Studio 2013 Problem
1st of all, sry I know this isn't exactly code..but it's an IDE so i guess it's kinda connected.. in a way. Anyways I just tought someone here might be able to help. So after having an installed VS 2012 I installed VS 2013 and everything was ok untill I create a new project and every time I do that, start the program and create a project for the 1st time I get this lil fella: http://i.imgur.com/L4kBtPi.png
Now some people suggest updating Web Essentials, which I did, uninstalled then reinstalled it, but doesn't help. I'm open to suggestions. ))
Remove all extension, restart and check if error persist. If not install extensions one by one until you got the error again, and them you will know which one is causing problems.
Well I uninstalled both VSs and did a clean install of VS2k13 which fixed the problem. ))
