Virtualized Mint Connect to home subnet
Hey guys I am running a Virtual instance of Mint. For some reason that I am not aware of the default network is a 10.10.10.xxx network. However our home network subnet is a 192.168.0.xxx I was wondering how to get the mint virtual instance to join our home network to use our SMB shared drives and services.
This is most likelly caused by a virtualbox network setting.
You should play arround with the network adapter settings in Vbox.
Bridged / nat etc.
You want to configure the virtual network interface as a bridge rather than NAT, then your VM will connect to your local network same as the host machine.
