Nope, you can't run a type 1 hypervisor from a windows host.
WMWare doesn't share, it virtualizes the GPU. Your OpenSuSE install in VMPlayer doesn't see the kernel that governs your hardware.
If you run linux as a host, you can do type 1 virtualization without a standalone hypervisor, because linux can share the kernel. It can do so on many different levels: the smallest form of virtualization being lxc, which creates an application container, moving up to qemu, which shares the kernel but virtualizes all hardware, to kvm, which shares the kernel and paravirtualizes as much hardware as possible.
When you use a standalone type 1 hypervisor, you can pass through hardware directly, because there is no host display server running on it. So for instance, if you would install Xen hypervisor or vSphere, a virtual machine could access your GPU directly. You would then install Windows and linux guests onto that hypervisor, and they would think that they were all bare metal installs.
When you use virtualization from within a GNU/Linux host, the host system still has a running display server, so it needs access to a GPU. You can unbind the GPU from the host system in a running X session like a standalone hypervisor does that, and that's called VGA passthrough, and that's not that easy with most hardware because of proprietary graphics drivers issues on open source software systems, so basically, it only works with most AMD GPUs and some Intel GPUs. The other option is to use a second GPU as a dedicated passthrough device, and that is called PCI passthrough. It's much easier to set up, but of course it requires either two cables to the monitor and input switching on the monitor, or two monitors, or a KVM switch, because you'll be bothered with two separate video outputs. For allround use, the iGPU in Intel CPUs is more than enough to keep the host display server up, while a high performance gaming-orientated dedicated GPU card is passed through to a host, which can either be another linux install for use with Steam for linux, or a Windows install for gaming in Windows.
Why doesn't everybody use a standalone type 1 hypervisor? Because most people that want to virtualize, want to be able to control containers with proprietary software from the outside for security purposes, and for that, you need a full-featured host, because a standalone hypervisor doesn't offer that functionality, so for instance, in a company, if you need a software security certification, you need to run something like Xen server and have every separate guest OS also certified, which excludes the use of closed source guests like Windows, or you can use xen or kvm from within a linux host, which offers the same performance because it also shares the kernel and paravirtualizes, in which case the host system is certified and you can still use a Windows guest without losing the security clearance or occurring liabilities. People that don't care about what proprietary software does or does not do however, are better off with a type 1 standalone hypervisor, like Xen server for instance, and installing their different OS's on top of that, as it's much easier to set up. You still need the hardware to have VT-d or AMD-Vi for it to be fully functional when running multiple containers, and Xen Server is open source, as in the open source version is downloadable from xenserver.org. For instance, if you were to install xenserver on your system, you could pull an image of your existing Windows install and of your linux virtual machine, and import the both of them to Xenserver, and you could switch between the two that would run simultaneously and use the hardware directly, but you could not use your linux system to filter the activities of the Windows system. You would however benefit from the other benefits of virtualization, namely being able to snapshot your installs and restore them without reinstalling if they are screwed up, use the same installs on different machines, etc...
