UPDATED:
I'm going to go with the FX-6300 and the R9 270, unless prices decide to spike up for some reason.
I've decided to make the long worthwhile trip to Microcenter from my location in order to take advantage of their CPU/Mobo Combo deals. Of course, I'll probably carpool to save on fuel, and if the prices of this list are similar to prices @Microcenter with tax, I will probably make the purchase.
http://pcpartpicker.com/p/3z1v0
ORIGINAL POST:
Greetings fellow humans, dogs, cats, and lizards alike,
This will be my very first build of my life. Currently I am using a laptop that struggles to edit even 480p videos of me playing classics on emulators with the likes of A Link to the Past, F-Zero, Mario Kart and others. Although I could probably upgrade it to 4GB of DDR2 RAM, I don't think it would make much of a difference.
For this build I will primarily be playing and recording racing sims like Assetto Corsa, rFactor, iRacing, Game Stock Car 2013, among others. I do not intend to live stream as of yet because my internet connection is not ideal, and I intend to wait until fiber is rolled out in my town. I'll probably play other more mainstream games as well as Steam games like Rust, GMod, Minecraft, Star Citizen, Borderlands 2, etc. ATM I only need to record at 720p with Open Broadcaster or Action, but I'd like to play most games when I'm not recording at 1080p at medium to high settings. (while maxing out at 60 fps)
As for the monitor and Windows, I'm probably just going to use the Windows 7 Home Premium 64 bit code from my laptop, and just get a cheap DVI or HDMI 60hz monitor from craigslist to save some money. Then I'll probably just install a 32 bit linux distro on my laptop to get acquainted with linux.
What do you guys recommend to buy used? Maybe I can purchase some used items like the GPU and maybe a case or MOBO from eBay to save a few more dollars or to upgrade to something slightly better.
I'm currently going for the FX-6300 for the cpu and the R7 260x for the gpu as they seem to be very good bang for your buck parts to maximize my dollar value. I've also considered the GTX 750 as it seems to draw less power than the 260x for the same performance, however I have yet to find a similarly priced model.
I am currently halfway to saving up for the build, and I will most likely be getting a part time job to aid in the funding in my 1st build. I don't intend to overclock as of yet, because I live in Texas and I do not have AC so keeping the computer's temp down will be difficult enough without overclocking. After a month of continued research, here is the list on pcpartpicker that I have compiled.
http://pcpartpicker.com/p/3rgRD
