Video Editing and Rendering, Crysis 3 ULTRA No AA or DoF, and 3D Vision 2 build
Will this build be sufficient for video editing and rendering, and playing Crysis 3 Ultra 3D No AA and no DoF?
BUDGET: $2500~, MUST include Os, Monitor, 3d Kit, and Mouse that I chose.
http://pcpartpicker.com/user/Frostbyter/saved/1owk
Reason for two 660tis, is because I saw Linus's video on the GTX Titan for 3d 1080p gaming, and saw that the "bang for the buck" solution was sufficient enough to go over 60fps in Crysis 3 at Ultra, even with AA on. I can expect better performance with AA off, am I correct?
Thanks!
For that pice this is the best you can get
http://pcpartpicker.com/p/MPEU
Its got a faster CPU which will render things faster and last longer before it needs to be replaced performance wise
a better SSD that will be faster and Extremly reliable
Cheaper 660Ti's with better coolers that will be much cooler and a lot quieter and i Higher OC straigt off
An awesome Mobo with Thunderbolt if you end up using it in the future that also has a great VRM design so you can overclock
And last but not least with a case like that it would be a sin not to watercool so i threw in the XSPC kit which will let you OC the crap out of your CPU, if not grab a smaller case and Kracken X60
And yes, you can expect much better performance with AA if, if you can live with the jagged edges.
Thank you! I might HAVE to go with that watercooling setup, it is too tempting not to. And, I dodnt think it was possible to get a 3770k in the loop of that system. Thank you for that awesome recommendation!
Thats a lower end kit as far as loops go, so if your willing to push your budget or switch some things up id suggest getting something like this
 http://www.frozencpu.com/products/17360/ex-wat-227/Alphacool_NexXxoS_Cool_Answer_360_DDCXT_-_Kit.html
Definitley one of the best kits for the money and if you threw in another 240mm slim or thick rad youd be able to add on the 2 GPU's to the loop in the future, it would cost a good bit more though.
