I recently started recording my games, because once in a blue moon i will do something epic by accident. i use open broadcaster to record my game play, the problem is when i try to convert or compress the video to a more common format i seem to lose clarity in the video and it really bugs me. is there something that i am doing wrong or is that just the way tha it is?. i use any video converter ultimate. any help would be appreciated
Which format exactly? The vast majority of formats do just as you say and compress the file, meaning the quality will degrade so you're probably not doing anything wrong. You could try a less compressed file format or less heavy compression or even a use a different program, such as handbrake.
Well i convert to MP4. is there another common format that doesnt degrade as much?
I would try MKV, it is nowhere near as compressed.
Use h.264 with variable bitrate from 14-18 MBps.
H.264 is just another type of MP4, meaning he is most likely already using H.264 encoding.
I am aware. Generally h.264 has very decent clarity, so I specified an optimal bitrate to be sure he wasn't using an incredibly low bitrate without knowing it. There is a HUGE difference between a .mp4 that's 3MBps and one that's 18MBps.
I have a similar sort of question. I’m currently using MakeMKV to rip all my Blu-Ray’s. they are all ripping with no compression. I’m quickly filling my 12tb HDD. what is the best method to shrink the size of the files and keep as much of the quality as possible. no idea what I’m looking for in compression software.
is this programme any good for instance.
