Development takes time, you cant expect all software to switch over over night. And I'll even say some software will never get wayland support (thats why xwayland exists), but most modern software will get support over time.
Wayland is just that, a spec.... Compositors implement that spec. A spec with more security in mind, a world in which you should not be able to write an app that can sniff another apps accessibility tree or install hooks to steal passwords... etc like you can do now in X11.
Sure there are missing features from the spec, like remote desktop and screen recording. X11 spec also does not cover screen recording BTW. Its just that ANY app can take a picture of you entire desktop and send it online. ANY app, including webbrowsers, worms...etc.
Wayland on the other hand does not allow this at the protocol/spec level, instead they give that choice to the compositor. For example Mutter might decide to expose an API so that this can be done.
Lets say, I waited for MBP refresh for over 2 years, I waited for Zen for over 1 year.... If I wait for vega then something else might come along and I will wait some more... is the never ending story!! in this waiting game my desktop is now 10 years old!!!! OMG!!! bios from 2006! with a few updates like SDD's running under speed... I did update the video card to a 550ti back in the day!
How well does the 1050ti play with multiple displays? I'm a two 1080p monitors at 60hz kind of guy seeing as how I only play chess, go and civilization rarely.
I usually buy Sapphire because they actually make the protos and pro versions for AMD itself. I've never had bad experiences with them, but then I haven't heard much bad from any AMD card vendor tbh, and I wouldn't pay extra for a brand lol
