Ultra
February 5, 2009, 8:27am
#1
OK, so I've been looking at an EVGA 8800GS for a about a week for $45. I just found another ad for a 7950 GT 512MB for $50. $50 is my limit, since I blew all my money on everything else for my build, and I'm saving for Windows 7+DX11 card come fall.
Which is better?
8800GS:
384MB
192-bit
96 stream processors
GDDR3
7950GT:
512MB
256-bit
GDDR3
? Stream processors
I'll be using XP, 1440x900
dont be fooled by the better specs it shows 8800 all the way
tough call, its all in the memory and core clocks though, do you know those? im gonna assume they have roughly the same number of stream processors
on second thought get this one
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150247
21DD23
February 5, 2009, 8:44am
#5
8800 GS kills that 7950.
i have the card. the evga one its the best bang for buck ur ever get. did u even read the review on it? did i mention its the quietest consumer gpu with a fan
http://www.techpowerup.com/reviews/EVGA/GeForce_8800_GS
21DD23
February 5, 2009, 8:47am
#6
plus 7900's dosent support dx 10
Ultra
#7
George wrote 10 minutes ago »
8800GS: 550MHZ core clock 1375MHZ Shader clock 800MHZ memory clock
7950GT: 550 MHZ core clock ??? Mhz shader clock 1400 MHZ Memeory clock
Ultra
February 5, 2009, 8:48am
#8
21DD23 wrote 35 seconds ago »
I'm using XP til windows 7, I'll only be using DX9
21DD23
February 5, 2009, 8:49am
#9
turst me ur get better frames with te 8800, i mean its a whole different chip, wat would u trust more. the G92 or that other chip. just read the review link i sent
21DD23
February 5, 2009, 8:50am
#10
iight idk, if u read but in crysis this card beat the 3870x2, i dont think alot of cards thats 50 bucks can beat something thats still over 150
Ultra
February 5, 2009, 8:53am
#11
I'm still doubtful, which card would be best for DX9?
21DD23
February 5, 2009, 8:54am
#12
this one, gosh man, im gonna hve to post the revie manually for u
why are you even comparing those two cards. if you want to comepair it to something do so to the 3850 or 3870 or the older 8800gts
Ultra
February 5, 2009, 8:57am
#14
I looked at the review, but the 512MB and 256-bit.
21DD23
February 5, 2009, 8:58am
#15
Crysis DX9 1024 768 [b]edit:High not med[/b] mistake
3870X2 46.7 FPS
[b]8800 GS - 48.4FPS[/b]
8800 GTX - 50.07 FPS
Fan Noise
Idle, First place
8800 GS - 20.3dba
Load, First place
22.4dba
Techpowerup Conclusion
[b]9.8/10[/b]
21DD23
February 5, 2009, 8:59am
#16
your res is not too big for this card.
Ask logan about this card, he did a review on it.
w8 let me pull up the video.
This is the one you want EVGA 8800 GS
http://www.youtube.com/watch?v=4liQVXtfAB0
This is the one i have EVGA 8800 GS SC
http://www.youtube.com/watch?v=obOgh2Mi2ZM
in crysis warhead. 1024 768 DX10, i get a about aver 37FPS
on a athlon x2 4200
Ultra
February 5, 2009, 9:15am
#17
OK thanks, I'll definitely get the 8800GS. Can I play Crysis on High with this thing in DX9? I want to play in 1280x800 at least, and I have a Q9400 with a Zalman CNPS8700LED so I'm gonna OC to around 3.3 GHZ.
21DD23
February 5, 2009, 9:18am
#18
wow ur at least get like 40+fps
Ultra
February 5, 2009, 9:19am
#19
OK, I'm gonna buy this thing on friday hopefully.
wow that GS seems like a great card for the price if you buy it you should make it the PhysX card.
