I'm building a computer for my brother, and I'm wondering if a 660Ti 3GB (EVGA Superclocked) could run games, such as BF3, on his 55" TV at a decent frame rate.
Aaaaand Go!
Guessing that the TV is 1920X1080 the 660TI 3GB would run anything very nicely.
Corey
its not size that makes a difference
its resolution, what is the resolution
I'd also assume that his TV is running 1080p( a 720p 55" TV? Hell no). As Phosgene said, the size doesn't matter. The resolution does. Heck, if there was a 15" screen with a 4K resolution, even a 7970 3GB will have some problems maxing out games on it. So assuming it's 1080p, I'd say yes
I figured this would be the case. Just double checking before I put any money down.
