Hi,
here is a list of the computer parts I am aiming for:
(this build is manly for using sidefx Houdini running/caching water and fluid simulations and rendering with redshift, Arnold and Octane. I will use it to run Cinema 4D and After Effects
with the element 3D from videocopilot as well)
AMD Threadripper 2970WX 3 GHz 24-Core Processor
NZXT Kraken X62 Rev 2 98.17 CFM Liquid CPU Cooler
ASRock X399 Taichi ATX sTR4 Motherboard
Corsair Vengeance RGB Pro 128 GB (8 x 16 GB) DDR4-3200 Memory
NVIDIA GeForce RTX 2080 SUPER 8 GB Video Card
EVGA SuperNOVA G3 850 W 80+ Gold Certified Fully Modular ATX Power Supply
Thermaltake View 71 TG RGB ATX Full Tower Case
Questions:
1.is the ram good choice since I am not sure those run with the Samsung B-die chip, (according to some PC builders works better with the Thread-ripper processors )is there
anyone in here with a better suggestion?
2.I would like to get the RTX2080Ti but some people told me RTX2080super performs
well enough, what do you guys think?
- any thoughts about the rig?
Thank you guys in advance.
