I’m passing through a gtx 1080 and a usb pci-e controller. they are in the same iommu group.The pci-controller is a RENESAS model. My cpu is a 10900k and my motherboard is the gigabyte z490 vision d. I don’t need to use the acs patch, so there should be no problems there. The devices are passed through just fine. I don’t have any sort of instability or issues on the host. I’m giving it 6 cores 2 threads(though i’ve tried many other combinations and they all have the same issue). Also when it hangs, i’m not in a game or anything the makes the vm work hard. it’s just random web browsing and setting up stuff. i’m running pop os 20.04, but I was running pop os 20.10 and I was having similar issues.
this is some of my dmesg output
[ 0.000000] Linux version 5.8.0-7630-generic (buildd@lgw01-amd64-001) (gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #32~1605108853~20.04~8bcf10e-Ubuntu SMP Wed Nov 11 22:42:16 UTC (Ubuntu 5.8.0-7630.32~1605108853~20.04~8bcf10e-generic 5.8.17)
[ 0.000000] Command line: initrd=\EFI\Pop_OS-cfb4f6a1-989e-4b78-89a5-518b92af6490\initrd.img root=UUID=cfb4f6a1-989e-4b78-89a5-518b92af6490 ro quiet loglevel=0 systemd.show_status=false splash intel_iommu=on vfio-pci.ids=10de:1b80,10de:10f0,1912:0014 mitigations=off
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Hygon HygonGenuine
[ 0.000000] Centaur CentaurHauls
[ 0.000000] zhaoxin Shanghai
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
[ 0.000000] x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
[ 0.000000] x86/fpu: xstate_offset[9]: 960, xstate_sizes[9]: 8
[ 0.000000] x86/fpu: Enabled xstate features 0x21f, context size is 968 bytes, using 'compacted' format.
[ 0.000000] reserve setup_data: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000100000000-0x0000000cbe7fffff] usable
[ 0.000000] efi: EFI v2.70 by American Megatrends
[ 0.000000] efi: ACPI=0x38719000 ACPI 2.0=0x38719014 SMBIOS=0x39a49000 SMBIOS 3.0=0x39a48000 MEMATTR=0x2f4d6298 ESRT=0x33db0998 RNG=0x39a78b18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] random: fast init done
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] SMBIOS 3.2.0 present.
[ 0.000000] DMI: Gigabyte Technology Co., Ltd. Z490 VISION D/Z490 VISION D, BIOS F7b 11/03/2020
[ 0.000000] tsc: Detected 3700.000 MHz processor
[ 0.000554] tsc: Detected 3699.850 MHz TSC
[ 0.000554] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000555] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000561] last_pfn = 0xcbe800 max_arch_pfn = 0x400000000
[ 0.000564] MTRR default type: write-back
[ 0.000564] MTRR fixed ranges enabled:
[ 0.000565] 00000-9FFFF write-back
[ 0.000566] A0000-BFFFF uncachable
[ 0.000566] C0000-FFFFF write-protect
[ 0.000567] MTRR variable ranges enabled:
[ 0.000568] 0 base 0080000000 mask 7F80000000 uncachable
[ 0.000568] 1 base 0040000000 mask 7FC0000000 uncachable
[ 0.000569] 2 base 003C000000 mask 7FFC000000 uncachable
[ 0.000569] 3 base 003B000000 mask 7FFF000000 uncachable
[ 0.000570] 4 base 2000000000 mask 6000000000 uncachable
[ 0.000571] 5 base 1000000000 mask 7000000000 uncachable
[ 0.000571] 6 base 4000000000 mask 4000000000 uncachable
[ 0.000571] 7 disabled
[ 0.000572] 8 disabled
[ 0.000572] 9 disabled
[ 0.000953] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.001093] last_pfn = 0x39f00 max_arch_pfn = 0x400000000
[ 0.006363] found SMP MP-table at [mem 0x000fcf70-0x000fcf7f]
[ 0.006372] esrt: Reserving ESRT space from 0x0000000033db0998 to 0x0000000033db09d0.
[ 0.006376] e820: update [mem 0x33db0000-0x33db0fff] usable ==> reserved
[ 0.006400] check: Scanning 1 areas for low memory corruption
[ 0.006403] Using GB pages for direct mapping
[ 0.006654] secureboot: Secure boot disabled
[ 0.006655] RAMDISK: [mem 0x29067000-0x2e572fff]
[ 0.006665] ACPI: Early table checksum verification disabled
[ 0.006667] ACPI: RSDP 0x0000000038719014 000024 (v02 ALASKA)
[ 0.006669] ACPI: XSDT 0x0000000038718728 0000E4 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.006673] ACPI: FACP 0x00000000382FA000 000114 (v06 ALASKA A M I 01072009 AMI 00010013)
[ 0.006676] ACPI: DSDT 0x00000000382B6000 043E1E (v02 ALASKA A M I 01072009 INTL 20160527)
[ 0.006678] ACPI: FACS 0x00000000387BB000 000040
[ 0.006680] ACPI: MCFG 0x00000000382FF000 00003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.006682] ACPI: SSDT 0x00000000382FC000 0020AD (v02 CpuRef CpuSsdt 00003000 INTL 20160527)
[ 0.006684] ACPI: SSDT 0x00000000382FB000 000A52 (v02 PmRef ItbmSci 00003000 INTL 20160527)
[ 0.006686] ACPI: FIDT 0x00000000382B5000 00009C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.006688] ACPI: SSDT 0x00000000382AC000 0082AD (v01 GBT GSWApp 00000001 INTL 20160527)
[ 0.006690] ACPI: SSDT 0x00000000382A8000 0031DA (v02 SaSsdt SaSsdt 00003000 INTL 20160527)
[ 0.006692] ACPI: SSDT 0x00000000382A5000 002703 (v02 Intel PegSsdt 00001000 INTL 20160527)
[ 0.006694] ACPI: HPET 0x0000000038301000 000038 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.006696] ACPI: SSDT 0x00000000382A3000 001EB6 (v02 ALASKA A M I 00001000 INTL 20160527)
[ 0.006697] ACPI: SSDT 0x00000000382A1000 00147B (v02 ALASKA A M I 00001000 INTL 20160527)
[ 0.006699] ACPI: SSDT 0x000000003829D000 00360B (v02 INTEL xh_cmsd4 00000000 INTL 20160527)
[ 0.006701] ACPI: NHLT 0x000000003829B000 001821 (v00 ALASKA A M I 01072009 AMI 01000013)
[ 0.006703] ACPI: LPIT 0x0000000038300000 000094 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.006704] ACPI: SSDT 0x0000000038297000 002720 (v02 ALASKA A M I 00001000 INTL 20160527)
[ 0.006706] ACPI: SSDT 0x0000000038294000 0025B2 (v02 ALASKA A M I 00000000 INTL 20160527)
[ 0.006708] ACPI: DBGP 0x0000000038293000 000034 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.006710] ACPI: DBG2 0x0000000038292000 000054 (v00 ALASKA A M I 01072009 AMI 01000013)
[ 0.006711] ACPI: SSDT 0x0000000038290000 001B67 (v02 ALASKA A M I 00001000 INTL 20160527)
[ 0.006713] ACPI: DMAR 0x000000003828F000 0000A8 (v01 INTEL EDK2 00000002 01000013)
[ 0.006715] ACPI: BGRT 0x000000003828E000 000038 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.006716] ACPI: WSMT 0x000000003829A000 000028 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.006718] ACPI: APIC 0x000000003828D000 000164 (v04 ALASKA A M I 01072009 AMI 00010013)
[ 0.006720] ACPI: FPDT 0x000000003828C000 000044 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.006726] ACPI: Local APIC address 0xfee00000
[ 0.007112] No NUMA configuration found
[ 0.007113] Faking a node at [mem 0x0000000000000000-0x0000000cbe7fffff]
[ 0.007120] NODE_DATA(0) allocated [mem 0xcbe7d6000-0xcbe7fffff]
[ 0.007385] Zone ranges:
[ 0.007386] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.007387] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.007388] Normal [mem 0x0000000100000000-0x0000000cbe7fffff]
[ 0.007388] Device empty
[ 0.007389] Movable zone start for each node
[ 0.007391] Early memory node ranges
[ 0.007391] node 0: [mem 0x0000000000001000-0x000000000005cfff]
[ 0.007392] node 0: [mem 0x000000000005e000-0x000000000009ffff]
[ 0.007392] node 0: [mem 0x0000000000100000-0x0000000032387fff]
[ 0.007393] node 0: [mem 0x0000000032389000-0x00000000323abfff]
[ 0.007393] node 0: [mem 0x00000000323ad000-0x00000000371d1fff]
[ 0.007394] node 0: [mem 0x0000000039eff000-0x0000000039efffff]
[ 0.007394] node 0: [mem 0x0000000100000000-0x0000000cbe7fffff]
[ 0.007752] Zeroed struct page in unavailable ranges: 42641 pages
[ 0.007752] Initmem setup node 0 [mem 0x0000000000001000-0x0000000cbe7fffff]
[ 0.007753] On node 0 totalpages: 12540271
[ 0.007754] DMA zone: 64 pages used for memmap
[ 0.007754] DMA zone: 28 pages reserved
[ 0.007755] DMA zone: 3998 pages, LIFO batch:0
[ 0.007774] DMA32 zone: 3464 pages used for memmap
[ 0.007774] DMA32 zone: 221649 pages, LIFO batch:63
[ 0.008646] Normal zone: 192416 pages used for memmap
[ 0.008646] Normal zone: 12314624 pages, LIFO batch:63
[ 0.057364] Reserving Intel graphics memory at [mem 0x3b800000-0x3f7fffff]
[ 0.057965] ACPI: PM-Timer IO Port: 0x1808
[ 0.057966] ACPI: Local APIC address 0xfee00000
[ 0.058517] Policy zone: Normal
[ 0.058518] Kernel command line: initrd=\EFI\Pop_OS-cfb4f6a1-989e-4b78-89a5-518b92af6490\initrd.img root=UUID=cfb4f6a1-989e-4b78-89a5-518b92af6490 ro quiet loglevel=0 systemd.show_status=false splash intel_iommu=on vfio-pci.ids=10de:1b80,10de:10f0,1912:0014 mitigations=off
[ 0.058605] DMAR: IOMMU enabled
[ 0.061177] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[ 0.062446] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.062569] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.133604] Memory: 48941636K/50161084K available (14339K kernel code, 2563K rwdata, 8868K rodata, 2636K init, 4900K bss, 1219448K reserved, 0K cma-reserved)
[ 0.133609] random: get_random_u64 called from kmem_cache_open+0x2d/0x410 with crng_init=1
[ 0.133714] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=20, Nodes=1
[ 0.133723] ftrace: allocating 46180 entries in 181 pages
[ 0.146394] ftrace: allocated 181 pages with 5 groups
[ 0.146495] rcu: Hierarchical RCU implementation.
[ 0.146496] rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=20.
[ 0.146496] Trampoline variant of Tasks RCU enabled.
[ 0.146497] Rude variant of Tasks RCU enabled.
[ 0.146497] Tracing variant of Tasks RCU enabled.
[ 0.146497] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.146498] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=20
[ 0.148934] NR_IRQS: 524544, nr_irqs: 2216, preallocated irqs: 16
[ 0.149465] random: crng done (trusting CPU's manufacturer)
[ 0.149487] Console: colour dummy device 80x25
[ 0.149491] printk: console [tty0] enabled
[ 0.149505] ACPI: Core revision 20200528
[ 0.149949] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[ 0.150091] APIC: Switch to symmetric I/O mode setup
[ 0.150092] DMAR: Host address width 39
[ 0.150093] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ 0.150097] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[ 0.150098] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.150100] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.150101] DMAR: RMRR base: 0x000000397db000 end: 0x00000039a24fff
[ 0.150102] DMAR: RMRR base: 0x0000003b000000 end: 0x0000003f7fffff
[ 0.150103] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
[ 0.150104] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.150104] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.153130] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.153131] x2apic enabled
[ 0.153162] Switched APIC routing to cluster x2apic.
[ 0.162366] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.182009] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x6aa99074b1c, max_idle_ns: 881590506587 ns
[ 0.182011] Calibrating delay loop (skipped), value calculated using timer frequency.. 7399.70 BogoMIPS (lpj=14799400)
[ 0.182013] pid_max: default: 32768 minimum: 301
[ 0.185908] LSM: Security Framework initializing
[ 0.185915] Yama: becoming mindful.
[ 0.185932] AppArmor: AppArmor initialized
[ 0.186033] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.186098] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.186303] mce: CPU0: Thermal monitoring enabled (TM1)
[ 0.186330] process: using mwait in idle threads
[ 0.186332] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[ 0.186332] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[ 0.186335] Speculative Store Bypass: Vulnerable
[ 0.186528] Freeing SMP alternatives memory: 40K
[ 0.190088] smpboot: CPU0: Intel(R) Core(TM) i9-10900K CPU @ 3.70GHz (family: 0x6, model: 0xa5, stepping: 0x5)
[ 0.190156] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.190160] ... version: 4
[ 0.190161] ... bit width: 48
[ 0.190161] ... generic registers: 4
[ 0.190161] ... value mask: 0000ffffffffffff
[ 0.190162] ... max period: 00007fffffffffff
[ 0.190162] ... fixed-purpose events: 3
[ 0.190162] ... event mask: 000000070000000f
[ 0.190190] rcu: Hierarchical SRCU implementation.
[ 0.191162] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.191270] smp: Bringing up secondary CPUs ...
[ 0.191322] x86: Booting SMP configuration:
[ 0.191322] .... node #0, CPUs: #1 #2 #3 #4 #5 #6 #7 #8 #9 #10 #11 #12 #13 #14 #15 #16 #17 #18 #19
[ 0.211120] smp: Brought up 1 node, 20 CPUs
[ 0.211120] smpboot: Max logical packages: 1
[ 0.211120] smpboot: Total of 20 processors activated (147994.00 BogoMIPS)
[ 0.215131] devtmpfs: initialized
[ 0.215131] x86/mm: Memory block size: 128MB
[ 0.216071] PM: Registering ACPI NVS region [mem 0x32388000-0x32388fff] (4096 bytes)
[ 0.216071] PM: Registering ACPI NVS region [mem 0x38302000-0x387bbfff] (4956160 bytes)
[ 0.216071] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.216071] futex hash table entries: 8192 (order: 7, 524288 bytes, linear)
[ 0.216071] pinctrl core: initialized pinctrl subsystem
[ 0.216071] PM: RTC time: 21:09:15, date: 2020-11-24
[ 0.216071] thermal_sys: Registered thermal governor 'fair_share'
[ 0.216071] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.216071] thermal_sys: Registered thermal governor 'step_wise'
[ 0.216071] thermal_sys: Registered thermal governor 'user_space'
[ 0.216071] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.216071] NET: Registered protocol family 16
[ 0.218213] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.218404] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.218599] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.218604] audit: initializing netlink subsys (disabled)
[ 0.218610] audit: type=2000 audit(1606252155.060:1): state=initialized audit_enabled=0 res=1
[ 0.218610] EISA bus registered
[ 0.218610] cpuidle: using governor ladder
[ 0.218610] cpuidle: using governor menu
[ 1.473889] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[ 1.475433] acpi PNP0A08:00: _OSC: platform does not support [AER]
[ 1.478317] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME PCIeCapability LTR]
[ 1.483775] pci 0000:00:1b.0: Intel SPT PCH root port ACS workaround enabled
[ 1.483781] pci 0000:00:1b.0: PTM enabled (root), 4ns granularity
[ 1.484043] pci 0000:00:1b.4: [8086:06ac] type 01 class 0x060400
[ 1.484230] pci 0000:00:1b.4: PME# supported from D0 D3hot D3cold
[ 1.484269] pci 0000:00:1b.4: Intel SPT PCH root port ACS workaround enabled
[ 1.484274] pci 0000:00:1b.4: PTM enabled (root), 4ns granularity
[ 1.484535] pci 0000:00:1c.0: [8086:06b8] type 01 class 0x060400
[ 1.484706] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 1.484955] pci 0000:00:1c.1: [8086:06b9] type 01 class 0x060400
[ 1.485142] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 1.485177] pci 0000:00:1c.1: Intel SPT PCH root port ACS workaround enabled
[ 1.485182] pci 0000:00:1c.1: PTM enabled (root), 4ns granularity
[ 1.485434] pci 0000:00:1c.4: [8086:06bc] type 01 class 0x060400
[ 1.485636] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 1.485678] pci 0000:00:1c.4: Intel SPT PCH root port ACS workaround enabled
[ 1.485683] pci 0000:00:1c.4: PTM enabled (root), 4ns granularity
[ 1.485941] pci 0000:00:1d.0: [8086:06b0] type 01 class 0x060400
[ 1.486134] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 1.486172] pci 0000:00:1d.0: Intel SPT PCH root port ACS workaround enabled
[ 1.486177] pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
[ 1.486440] pci 0000:00:1d.4: [8086:06b4] type 01 class 0x060400
[ 1.486624] pci 0000:00:1d.4: PME# supported from D0 D3hot D3cold
[ 1.497845] iommu: Default domain type: Translated
[ 1.497845] SCSI subsystem initialized
[ 1.498017] libata version 3.00 loaded.
[ 1.498024] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 1.498024] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 1.498024] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 1.498024] pci 0000:00:02.0: vgaarb: no bridge control possible
[ 1.498024] pci 0000:01:00.0: vgaarb: bridge control possible
[ 1.498024] vgaarb: loaded
[ 1.498031] ACPI: bus type USB registered
[ 1.498038] usbcore: registered new interface driver usbfs
[ 1.498044] usbcore: registered new interface driver hub
[ 1.498073] usbcore: registered new device driver usb
[ 1.498088] pps_core: LinuxPPS API ver. 1 registered
[ 1.498088] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 1.498089] PTP clock support registered
[ 1.498112] EDAC MC: Ver: 3.0.0
[ 1.498256] Registered efivars operations
[ 1.498256] NetLabel: Initializing
[ 1.498256] NetLabel: domain hash size = 128
[ 1.498256] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 1.498256] NetLabel: unlabeled traffic allowed by default
[ 1.498256] PCI: Using ACPI for IRQ routing
[ 1.566650] PCI: pci_cache_line_size set to 64 bytes
[ 1.566894] e820: reserve RAM buffer [mem 0x0005d000-0x0005ffff]
[ 1.566895] e820: reserve RAM buffer [mem 0x29047018-0x2bffffff]
[ 1.566895] e820: reserve RAM buffer [mem 0x2f30c018-0x2fffffff]
[ 1.566896] e820: reserve RAM buffer [mem 0x2f39e018-0x2fffffff]
[ 1.566896] e820: reserve RAM buffer [mem 0x2f3eb018-0x2fffffff]
[ 1.566897] e820: reserve RAM buffer [mem 0x2fff4000-0x2fffffff]
[ 1.566897] e820: reserve RAM buffer [mem 0x32388000-0x33ffffff]
[ 1.566898] e820: reserve RAM buffer [mem 0x323ac000-0x33ffffff]
[ 1.566899] e820: reserve RAM buffer [mem 0x33db0000-0x33ffffff]
[ 1.566899] e820: reserve RAM buffer [mem 0x371d2000-0x37ffffff]
[ 1.566900] e820: reserve RAM buffer [mem 0x39f00000-0x3bffffff]
[ 1.566900] e820: reserve RAM buffer [mem 0xcbe800000-0xcbfffffff]
[ 1.566902] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 1.566902] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[ 1.568666] clocksource: Switched to clocksource tsc-early
[ 1.574657] VFS: Disk quotas dquot_6.6.0
[ 1.574669] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.574741] AppArmor: AppArmor Filesystem Enabled
[ 1.574755] pnp: PnP ACPI init
[ 1.575033] system 00:00: [io 0x0a00-0x0a2f] has been reserved
[ 1.575034] system 00:00: [io 0x0a30-0x0a3f] has been reserved
[ 1.575035] system 00:00: [io 0x0a40-0x0a4f] has been reserved
[ 1.575038] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.575139] system 00:01: [io 0x0680-0x069f] has been reserved
[ 1.575140] system 00:01: [io 0x164e-0x164f] has been reserved
[ 1.575142] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.575247] system 00:02: [io 0x1854-0x1857] has been reserved
[ 1.575249] system 00:02: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 1.575384] system 00:03: [mem 0xfc000000-0xfc00ffff] has been reserved
[ 1.575386] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.575521] system 00:04: [io 0x1800-0x18fe] could not be reserved
[ 1.575523] system 00:04: [mem 0xfd000000-0xfd69ffff] has been reserved
[ 1.575524] system 00:04: [mem 0xfd6c0000-0xfd6cffff] has been reserved
[ 1.575525] system 00:04: [mem 0xfd6f0000-0xfdffffff] has been reserved
[ 1.575526] system 00:04: [mem 0xfe000000-0xfe01ffff] could not be reserved
[ 1.575527] system 00:04: [mem 0xfe200000-0xfe7fffff] has been reserved
[ 1.575527] system 00:04: [mem 0xff000000-0xffffffff] has been reserved
[ 1.575529] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.575800] system 00:05: [io 0x2000-0x20fe] has been reserved
[ 1.575802] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.576424] system 00:06: [mem 0xfed10000-0xfed17fff] has been reserved
[ 1.576425] system 00:06: [mem 0xfed18000-0xfed18fff] has been reserved
[ 1.576426] system 00:06: [mem 0xfed19000-0xfed19fff] has been reserved
[ 1.576427] system 00:06: [mem 0xe0000000-0xefffffff] has been reserved
[ 1.576427] system 00:06: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 1.576428] system 00:06: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 1.576429] system 00:06: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 1.576430] system 00:06: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 1.576432] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.576762] system 00:07: [mem 0xfe038000-0xfe038fff] has been reserved
[ 1.576764] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.577554] pnp: PnP ACPI: found 8 devices
[ 1.582828] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 1.582866] NET: Registered protocol family 2
[ 1.583011] tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 1.583236] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 1.583585] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 1.583635] TCP: Hash tables configured (established 524288 bind 65536)
[ 1.583734] UDP hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 1.583850] UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 1.583953] NET: Registered protocol family 1
[ 1.583955] NET: Registered protocol family 44
[ 1.715593] DMAR: No ATSR found
[ 1.715655] DMAR: dmar0: Using Queued invalidation
[ 1.715657] DMAR: dmar1: Using Queued invalidation
[ 1.715910] pci 0000:00:00.0: Adding to iommu group 0
[ 1.715925] pci 0000:00:01.0: Adding to iommu group 1
[ 1.715932] pci 0000:00:01.1: Adding to iommu group 1
[ 1.715939] pci 0000:00:02.0: Adding to iommu group 2
[ 1.715948] pci 0000:00:12.0: Adding to iommu group 3
[ 1.715960] pci 0000:00:14.0: Adding to iommu group 4
[ 1.715966] pci 0000:00:14.2: Adding to iommu group 4
[ 1.715972] pci 0000:00:14.3: Adding to iommu group 5
[ 1.715982] pci 0000:00:16.0: Adding to iommu group 6
[ 1.715988] pci 0000:00:17.0: Adding to iommu group 7
[ 1.716012] pci 0000:00:1b.0: Adding to iommu group 8
[ 1.716031] pci 0000:00:1b.4: Adding to iommu group 8
[ 1.716060] pci 0000:00:1c.0: Adding to iommu group 9
[ 1.716078] pci 0000:00:1c.1: Adding to iommu group 9
[ 1.716095] pci 0000:00:1c.4: Adding to iommu group 9
[ 1.716119] pci 0000:00:1d.0: Adding to iommu group 10
[ 1.716140] pci 0000:00:1d.4: Adding to iommu group 10
[ 1.716161] pci 0000:00:1f.0: Adding to iommu group 11
[ 1.716169] pci 0000:00:1f.3: Adding to iommu group 11
[ 1.716176] pci 0000:00:1f.4: Adding to iommu group 11
[ 1.716182] pci 0000:00:1f.5: Adding to iommu group 11
[ 1.716189] pci 0000:00:1f.6: Adding to iommu group 11
[ 1.716192] pci 0000:01:00.0: Adding to iommu group 1
[ 1.716195] pci 0000:01:00.1: Adding to iommu group 1
[ 1.716198] pci 0000:02:00.0: Adding to iommu group 1
[ 1.716207] pci 0000:03:00.0: Adding to iommu group 8
[ 1.716214] pci 0000:04:00.0: Adding to iommu group 8
[ 1.716220] pci 0000:06:00.0: Adding to iommu group 9
[ 1.716226] pci 0000:40:00.0: Adding to iommu group 10
[ 1.723528] DMAR: Intel(R) Virtualization Technology for Directed I/O
[ 1.723528] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 1.723529] software IO TLB: mapped [mem 0x25047000-0x29047000] (64MB)
[ 1.723599] platform rtc_cmos: registered platform RTC device (no PNP device found)
[ 1.723825] check: Scanning for low memory corruption every 60 seconds
[ 1.724153] Initialise system trusted keyrings
[ 1.724160] Key type blacklist registered
[ 1.724178] workingset: timestamp_bits=36 max_order=24 bucket_order=0
[ 1.724978] zbud: loaded
[ 1.725145] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.725240] fuse: init (API version 7.31)
[ 1.725330] integrity: Platform Keyring initialized
[ 1.731438] Key type asymmetric registered
[ 1.731439] Asymmetric key parser 'x509' registered
[ 1.731443] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 1.731481] io scheduler mq-deadline registered
[ 1.731781] pcieport 0000:00:01.0: PME: Signaling with IRQ 122
[ 1.731839] pcieport 0000:00:01.1: PME: Signaling with IRQ 123
[ 1.732035] pcieport 0000:00:1b.0: PME: Signaling with IRQ 124
[ 1.732280] pcieport 0000:00:1b.4: PME: Signaling with IRQ 125
[ 1.732430] pcieport 0000:00:1c.0: PME: Signaling with IRQ 126
[ 1.732679] pcieport 0000:00:1c.1: PME: Signaling with IRQ 127
[ 1.732938] pcieport 0000:00:1c.4: PME: Signaling with IRQ 128
[ 1.733196] pcieport 0000:00:1d.0: PME: Signaling with IRQ 129
[ 1.733367] pcieport 0000:00:1d.4: PME: Signaling with IRQ 130
[ 1.733473] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.733510] efifb: probing for efifb
[ 1.733524] efifb: showing boot graphics
[ 1.733959] efifb: framebuffer at 0x40000000, using 3072k, total 3072k
[ 1.733960] efifb: mode is 1024x768x32, linelength=4096, pages=1
[ 1.733960] efifb: scrolling: redraw
[ 1.733961] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 1.733988] fbcon: Deferring console take-over
[ 1.733989] fb0: EFI VGA frame buffer device
[ 1.733993] intel_idle: MWAIT substates: 0x11142120
[ 1.734226] Monitor-Mwait will be used to enter C-1 state
[ 1.734228] Monitor-Mwait will be used to enter C-2 state
[ 1.734229] Monitor-Mwait will be used to enter C-3 state
[ 1.734231] ACPI: \_SB_.PR00: Found 3 idle states
[ 1.734232] intel_idle: v0.5.1 model 0xA5
[ 1.734631] intel_idle: Local APIC timer is reliable in all C-states
[ 1.734756] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 1.734770] ACPI: Sleep Button [SLPB]
[ 1.734791] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 1.734800] ACPI: Power Button [PWRB]
[ 1.734818] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 1.734837] ACPI: Power Button [PWRF]
[ 1.736330] ACPI: Invalid passive threshold
[ 1.736413] thermal LNXTHERM:00: registered as thermal_zone0
[ 1.736414] ACPI: Thermal Zone [TZ20] (17 C)
[ 1.736785] thermal LNXTHERM:01: registered as thermal_zone1
[ 1.736785] ACPI: Thermal Zone [TZ00] (28 C)
[ 1.736937] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 1.738214] Linux agpgart interface v0.103
[ 1.740750] loop: module loaded
[ 1.740913] libphy: Fixed MDIO Bus: probed
[ 1.740913] tun: Universal TUN/TAP device driver, 1.6
[ 1.740928] PPP generic driver version 2.4.2
[ 1.740952] VFIO - User Level meta-driver version: 0.3
[ 1.741032] vfio-pci 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=none
[ 1.758100] vfio_pci: add [10de:1b80[ffffffff:ffffffff]] class 0x000000/00000000
[ 1.778106] vfio_pci: add [10de:10f0[ffffffff:ffffffff]] class 0x000000/00000000
[ 1.798153] vfio_pci: add [1912:0014[ffffffff:ffffffff]] class 0x000000/00000000
[ 1.798163] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.798165] ehci-pci: EHCI PCI platform driver
[ 1.798174] ehci-platform: EHCI generic platform driver
[ 1.798180] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.798181] ohci-pci: OHCI PCI platform driver
[ 1.798186] ohci-platform: OHCI generic platform driver
[ 1.798191] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.798215] i8042: PNP: No PS/2 controller found.
[ 1.798384] mousedev: PS/2 mouse device common for all mice
[ 1.798755] rtc_cmos rtc_cmos: RTC can wake from S4
[ 1.799837] rtc_cmos rtc_cmos: registered as rtc0
[ 1.800135] rtc_cmos rtc_cmos: setting system clock to 2020-11-24T21:09:17 UTC (1606252157)
[ 1.800144] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 1.800148] i2c /dev entries driver
[ 1.800173] device-mapper: uevent: version 1.0.3
[ 1.800210] device-mapper: ioctl: 4.42.0-ioctl (2020-02-27) initialised: [email protected]
[ 1.800220] platform eisa.0: Probing EISA bus 0
[ 1.800221] platform eisa.0: EISA: Cannot allocate resource for mainboard
[ 1.800222] platform eisa.0: Cannot allocate resource for EISA slot 1
[ 1.800222] platform eisa.0: Cannot allocate resource for EISA slot 2
[ 1.800223] platform eisa.0: Cannot allocate resource for EISA slot 3
[ 1.800224] platform eisa.0: Cannot allocate resource for EISA slot 4
[ 1.800224] platform eisa.0: Cannot allocate resource for EISA slot 5
[ 1.800225] platform eisa.0: Cannot allocate resource for EISA slot 6
[ 1.800225] platform eisa.0: Cannot allocate resource for EISA slot 7
[ 1.800226] platform eisa.0: Cannot allocate resource for EISA slot 8
[ 1.800226] platform eisa.0: EISA: Detected 0 cards
[ 1.800228] intel_pstate: Intel P-state driver initializing
[ 1.801423] intel_pstate: HWP enabled
[ 1.801943] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.801944] EFI Variables Facility v0.08 2004-May-17
[ 1.811631] intel_pmc_core INT33A1:00: initialized
[ 1.811671] drop_monitor: Initializing network drop monitor service
[ 1.811801] NET: Registered protocol family 10
[ 1.814654] Segment Routing with IPv6
[ 1.814678] NET: Registered protocol family 17
[ 1.814721] Key type dns_resolver registered
[ 1.815779] microcode: sig=0xa0655, pf=0x2, revision=0xe2
[ 1.816250] microcode: Microcode Update Driver: v2.2.
[ 1.816252] IPI shorthand broadcast: enabled
[ 1.816255] sched_clock: Marking stable (1807676197, 8572762)->(1929378548, -113129589)
[ 1.816453] registered taskstats version 1
[ 1.816458] Loading compiled-in X.509 certificates
[ 1.816788] Loaded X.509 cert 'Build time autogenerated kernel key: aa806eb1b50349baae7cef42a6a3543132570bdf'
[ 1.816822] zswap: loaded using pool lzo/zbud
[ 1.816999] Key type ._fscrypt registered
[ 1.816999] Key type .fscrypt registered
[ 1.816999] Key type fscrypt-provisioning registered
[ 1.818006] Key type encrypted registered
[ 1.818007] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.818334] ima: No TPM chip found, activating TPM-bypass!
[ 1.818336] ima: Allocated hash algorithm: sha1
[ 1.818339] ima: No architecture policies found
[ 1.818344] evm: Initialising EVM extended attributes:
[ 1.818345] evm: security.selinux
[ 1.818345] evm: security.SMACK64
[ 1.818345] evm: security.SMACK64EXEC
[ 1.818345] evm: security.SMACK64TRANSMUTE
[ 1.818345] evm: security.SMACK64MMAP
[ 1.818346] evm: security.apparmor
[ 1.818346] evm: security.ima
[ 1.818346] evm: security.capability
[ 1.818346] evm: HMAC attrs: 0x1
[ 1.819485] PM: Magic number: 12:679:197
[ 1.819514] acpi device:52: hash matches
[ 1.819519] acpi PNP0100:00: hash matches
[ 1.819591] RAS: Correctable Errors collector initialized.
[ 1.820196] Freeing unused decrypted memory: 2040K
[ 1.820507] Freeing unused kernel image (initmem) memory: 2636K
[ 1.846120] Write protecting the kernel read-only data: 26624k
[ 1.846670] Freeing unused kernel image (text/rodata gap) memory: 2044K
[ 1.846914] Freeing unused kernel image (rodata/data gap) memory: 1372K
[ 1.855045] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.855128] Run /init as init process
[ 1.855129] with arguments:
[ 1.855129] /init
[ 1.855130] splash
[ 1.855130] with environment:
[ 1.855131] HOME=/
[ 1.855131] TERM=linux
[ 1.855131] intel_iommu=on
[ 1.894441] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
[ 1.894556] acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
[ 1.894608] acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
[ 1.898606] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.898610] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 1.899655] ahci 0000:00:17.0: version 3.0
[ 1.899695] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[ 1.899704] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 1.899864] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[ 1.899865] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.899866] usb usb1: Product: xHCI Host Controller
[ 1.899867] usb usb1: Manufacturer: Linux 5.8.0-7630-generic xhci-hcd
[ 1.899868] usb usb1: SerialNumber: 0000:00:14.0
[ 1.899901] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 3 ports 6 Gbps 0xe impl SATA mode
[ 1.899902] ahci 0000:00:17.0: flags: 64bit ncq sntf clo only pio slum part ems deso sadm sds apst
[ 1.899903] Intel(R) 2.5G Ethernet Linux Driver
[ 1.899903] Copyright(c) 2018 Intel Corporation.
[ 1.899939] hub 1-0:1.0: USB hub found
[ 1.899956] hub 1-0:1.0: 16 ports detected
[ 1.900161] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[ 1.900249] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 1.900342] nvme nvme0: pci function 0000:03:00.0
[ 1.900388] nvme nvme1: pci function 0000:04:00.0
[ 1.900415] nvme nvme2: pci function 0000:40:00.0
[ 1.901220] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.901220] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.901542] e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 1.902246] cryptd: max_cpu_qlen set to 1000
[ 1.902495] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.902497] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.902499] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.902527] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.08
[ 1.902528] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.902528] usb usb2: Product: xHCI Host Controller
[ 1.902529] usb usb2: Manufacturer: Linux 5.8.0-7630-generic xhci-hcd
[ 1.902530] usb usb2: SerialNumber: 0000:00:14.0
[ 1.902596] hub 2-0:1.0: USB hub found
[ 1.902624] hub 2-0:1.0: 10 ports detected
[ 1.904742] AVX2 version of gcm_enc/dec engaged.
[ 1.904742] AES CTR mode by8 optimization enabled
[ 1.905308] i2c i2c-0: 3/4 memory slots populated (from DMI)
[ 1.905817] i2c i2c-0: Successfully instantiated SPD at 0x50
[ 1.906311] i2c i2c-0: Successfully instantiated SPD at 0x51
[ 1.906817] i2c i2c-0: Successfully instantiated SPD at 0x52
[ 1.907486] nvme nvme1: missing or invalid SUBNQN field.
[ 1.907501] nvme nvme1: Shutdown timeout set to 8 seconds
[ 1.908051] nvme nvme2: missing or invalid SUBNQN field.
[ 1.908061] nvme nvme2: Shutdown timeout set to 8 seconds
[ 1.912727] nvme nvme0: 7/0/0 default/read/poll queues
[ 1.917534] nvme0n1: p1 p2 p3 p4
[ 1.922415] scsi host0: ahci
[ 1.922491] scsi host1: ahci
[ 1.922544] scsi host2: ahci
[ 1.922592] scsi host3: ahci
[ 1.922617] ata1: DUMMY
[ 1.922620] ata2: SATA max UDMA/133 abar m2048@0xae722000 port 0xae722180 irq 132
[ 1.922622] ata3: SATA max UDMA/133 abar m2048@0xae722000 port 0xae722200 irq 132
[ 1.922625] ata4: SATA max UDMA/133 abar m2048@0xae722000 port 0xae722280 irq 132
[ 1.923501] MXM: GUID detected in BIOS
[ 2.707659] usb-storage 2-3:1.0: USB Mass Storage device detected
[ 2.707856] usb-storage 2-3:1.0: Quirks match for vid 090c pid 1000: 400
[ 2.707970] scsi host4: usb-storage 2-3:1.0
[ 2.708141] usbcore: registered new interface driver usb-storage
[ 2.710116] usbcore: registered new interface driver uas
[ 2.746133] tsc: Refined TSC clocksource calibration: 3695.998 MHz
[ 2.746154] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x6a8d2284b57, max_idle_ns: 881590451434 ns
[ 2.746244] clocksource: Switched to clocksource tsc
[ 2.902500] system76_acpi: loading out-of-tree module taints kernel.
[ 2.902509] system76_acpi: module verification failed: signature and/or required key missing - tainting kernel
[ 2.904291] system76: Model does not utilize this driver
[ 2.967166] usbcore: registered new interface driver system76-io
[ 3.070012] raid6: avx2x4 gen() 42418 MB/s
[ 3.138012] raid6: avx2x4 xor() 22371 MB/s
[ 3.206012] raid6: avx2x2 gen() 55096 MB/s
[ 3.274012] raid6: avx2x2 xor() 33081 MB/s
[ 3.342012] raid6: avx2x1 gen() 47204 MB/s
[ 3.410012] raid6: avx2x1 xor() 27969 MB/s
[ 3.478012] raid6: sse2x4 gen() 23110 MB/s
[ 3.546012] raid6: sse2x4 xor() 12079 MB/s
[ 3.614012] raid6: sse2x2 gen() 23568 MB/s
[ 3.682012] raid6: sse2x2 xor() 14184 MB/s
[ 3.750012] raid6: sse2x1 gen() 19772 MB/s
[ 3.818012] raid6: sse2x1 xor() 10143 MB/s
[ 3.818012] raid6: using algorithm avx2x2 gen() 55096 MB/s
[ 3.818012] raid6: .... xor() 33081 MB/s, rmw enabled
[ 3.818013] raid6: using avx2x2 recovery algorithm
[ 3.818930] xor: automatically using best checksumming function avx
[ 3.819681] async_tx: api initialized (async)
[ 3.984605] scsi 4:0:0:0: Direct-Access Samsung Flash Drive 1100 PQ: 0 ANSI: 6
[ 3.985093] sd 4:0:0:0: Attached scsi generic sg1 type 0
[ 3.985668] sd 4:0:0:0: [sdb] 125313283 512-byte logical blocks: (64.2 GB/59.8 GiB)
[ 3.985907] sd 4:0:0:0: [sdb] Write Protect is off
[ 3.985911] sd 4:0:0:0: [sdb] Mode Sense: 43 00 00 00
[ 3.986086] sd 4:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 4.016223] sdb: sdb1 sdb2
[ 4.017993] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[ 4.234124] usb usb1-port9: Cannot enable. Maybe the USB cable is bad?
[ 4.314123] usb 1-7.2: new high-speed USB device number 4 using xhci_hcd
[ 4.415015] usb 1-7.2: New USB device found, idVendor=0451, idProduct=8342, bcdDevice= 1.00
[ 4.415020] usb 1-7.2: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 4.415023] usb 1-7.2: SerialNumber: 13010071B15D
[ 4.416537] hub 1-7.2:1.0: USB hub found
[ 4.416666] hub 1-7.2:1.0: 5 ports detected
[ 4.542785] usb 2-7: new SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 4.578917] usb 2-7: New USB device found, idVendor=0bda, idProduct=0411, bcdDevice= 1.24
[ 4.578922] usb 2-7: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.578925] usb 2-7: Product: 4-Port USB 3.1 Hub
[ 4.578928] usb 2-7: Manufacturer: Generic
[ 4.589592] hub 2-7:1.0: USB hub found
[ 4.591007] hub 2-7:1.0: 4 ports detected
[ 5.538114] usb usb1-port9: Cannot enable. Maybe the USB cable is bad?
[ 5.538179] usb usb1-port9: attempt power cycle
[ 5.618086] usb 1-7.3: new high-speed USB device number 6 using xhci_hcd
[ 5.721434] usb 1-7.3: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.26
[ 5.721439] usb 1-7.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.721442] usb 1-7.3: Product: USB2.0 Hub
[ 5.721445] usb 1-7.3: Manufacturer: GenesysLogic
[ 5.723265] hub 1-7.3:1.0: USB hub found
[ 5.723623] hub 1-7.3:1.0: 4 ports detected
[ 5.798082] usb 1-7.2.1: new high-speed USB device number 7 using xhci_hcd
[ 5.932696] usb 1-7.2.1: New USB device found, idVendor=0781, idProduct=558c, bcdDevice=10.12
[ 5.932701] usb 1-7.2.1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 5.932704] usb 1-7.2.1: Product: Extreme SSD
[ 5.932706] usb 1-7.2.1: Manufacturer: SanDisk
[ 5.932709] usb 1-7.2.1: SerialNumber: 313932354333343032303530
[ 5.940385] scsi host5: uas
[ 5.941663] scsi 5:0:0:0: Direct-Access SanDisk Extreme SSD 1012 PQ: 0 ANSI: 6
[ 5.944748] scsi 5:0:0:1: Enclosure SanDisk SES Device 1012 PQ: 0 ANSI: 6
[ 5.946559] sd 5:0:0:0: Attached scsi generic sg2 type 0
[ 5.946787] scsi 5:0:0:1: Attached scsi generic sg3 type 13
[ 5.948341] sd 5:0:0:0: [sdc] 1953523712 512-byte logical blocks: (1.00 TB/932 GiB)
[ 5.948341] sd 5:0:0:0: [sdc] 4096-byte physical blocks
[ 5.948628] sd 5:0:0:0: [sdc] Write Protect is off
[ 5.948629] sd 5:0:0:0: [sdc] Mode Sense: 67 00 10 08
[ 5.949155] sd 5:0:0:0: [sdc] Write cache: disabled, read cache: enabled, supports DPO and FUA
[ 5.949317] scsi 5:0:0:1: Wrong diagnostic page; asked for 1 got 8
[ 5.949318] scsi 5:0:0:1: Failed to get diagnostic page 0x1
[ 5.949319] scsi 5:0:0:1: Failed to bind enclosure -19
[ 5.949887] sd 5:0:0:0: [sdc] Optimal transfer size 1048576 bytes
[ 5.985676] usb 2-7-port2: Cannot enable. Maybe the USB cable is bad?
[ 6.003993] sdc: sdc1
[ 6.009960] sd 5:0:0:0: [sdc] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 6.010586] sd 5:0:0:0: [sdc] Attached SCSI disk
[ 6.010634] ses 5:0:0:1: Attached Enclosure device
[ 6.898113] usb usb1-port9: Cannot enable. Maybe the USB cable is bad?
[ 6.978086] usb 1-7.3.1: new full-speed USB device number 9 using xhci_hcd
[ 7.079636] usb 1-7.3.1: New USB device found, idVendor=0451, idProduct=2036, bcdDevice= 1.01
[ 7.079640] usb 1-7.3.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 7.079643] usb 1-7.3.1: Product: General Purpose USB Hub
[ 7.084579] hub 1-7.3.1:1.0: USB hub found
[ 7.084802] hub 1-7.3.1:1.0: 3 ports detected
[ 7.158086] usb 1-7.2.3: new full-speed USB device number 10 using xhci_hcd
[ 7.262007] usb 1-7.2.3: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.09
[ 7.262011] usb 1-7.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.262029] usb 1-7.2.3: Product: USB Receiver
[ 7.262032] usb 1-7.2.3: Manufacturer: Logitech
[ 7.279973] hid: raw HID events driver (C) Jiri Kosina
[ 7.285939] usbcore: registered new interface driver usbhid
[ 7.285941] usbhid: USB HID core driver
[ 7.291369] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7.2/1-7.2.3/1-7.2.3:1.0/0003:046D:C52B.0001/input/input4
[ 7.350462] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:14.0-7.2.3/input0
[ 7.351044] input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7.2/1-7.2.3/1-7.2.3:1.1/0003:046D:C52B.0002/input/input5
[ 7.351509] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7.2/1-7.2.3/1-7.2.3:1.1/0003:046D:C52B.0002/input/input6
[ 7.410388] input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7.2/1-7.2.3/1-7.2.3:1.1/0003:046D:C52B.0002/input/input7
[ 7.410835] hid-generic 0003:046D:C52B.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-7.2.3/input1
[ 7.411342] hid-generic 0003:046D:C52B.0003: hiddev1,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-7.2.3/input2
[ 7.599792] logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-7.2.3/input2
[ 7.721242] input: Logitech Wireless Device PID:4082 Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7.2/1-7.2.3/1-7.2.3:1.2/0003:046D:C52B.0003/0003:046D:4082.0004/input/input9
[ 7.721453] input: Logitech Wireless Device PID:4082 Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7.2/1-7.2.3/1-7.2.3:1.2/0003:046D:C52B.0003/0003:046D:4082.0004/input/input10
[ 7.721628] hid-generic 0003:046D:4082.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4082] on usb-0000:00:14.0-7.2.3/input2:1
[ 7.836729] input: Logitech MX Master 3 as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7.2/1-7.2.3/1-7.2.3:1.2/0003:046D:C52B.0003/0003:046D:4082.0004/input/input14
[ 7.837176] logitech-hidpp-device 0003:046D:4082.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech MX Master 3] on usb-0000:00:14.0-7.2.3/input2:1
[ 9.003593] usb 2-7-port2: Cannot enable. Maybe the USB cable is bad?
[ 9.970114] usb usb1-port9: Cannot enable. Maybe the USB cable is bad?
[ 9.970181] usb usb1-port9: unable to enumerate USB device
[ 10.050087] usb 1-7.2.4: new full-speed USB device number 12 using xhci_hcd
[ 10.152516] usb 1-7.2.4: New USB device found, idVendor=046d, idProduct=c545, bcdDevice= 2.00
[ 10.152521] usb 1-7.2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 10.152524] usb 1-7.2.4: Product: USB Receiver
[ 10.152527] usb 1-7.2.4: Manufacturer: Logitech
[ 10.164258] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7.2/1-7.2.4/1-7.2.4:1.0/0003:046D:C545.0005/input/input15
[ 10.164766] hid-generic 0003:046D:C545.0005: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-7.2.4/input0
[ 10.166521] input: Logitech USB Receiver Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7.2/1-7.2.4/1-7.2.4:1.1/0003:046D:C545.0006/input/input16
[ 10.226413] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7.2/1-7.2.4/1-7.2.4:1.1/0003:046D:C545.0006/input/input17
[ 10.226674] input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7.2/1-7.2.4/1-7.2.4:1.1/0003:046D:C545.0006/input/input18
[ 10.227020] hid-generic 0003:046D:C545.0006: input,hidraw3: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:14.0-7.2.4/input1
[ 10.228557] hid-generic 0003:046D:C545.0007: hiddev1,hidraw4: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-7.2.4/input2
[ 10.230066] usb 1-7.3.1.2: new full-speed USB device number 13 using xhci_hcd
[ 10.333046] usb 1-7.3.1.2: New USB device found, idVendor=1038, idProduct=1290, bcdDevice= 6.00
[ 10.333051] usb 1-7.3.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 10.333054] usb 1-7.3.1.2: Product: Arctis Pro Wireless
[ 10.333056] usb 1-7.3.1.2: Manufacturer: SteelSeries
[ 10.342205] hid-generic 0003:1038:1290.0008: hiddev2,hidraw5: USB HID v1.11 Device [SteelSeries Arctis Pro Wireless] on usb-0000:00:14.0-7.3.1.2/input0
[ 10.343567] hid-generic 0003:1038:1290.0009: hiddev3,hidraw6: USB HID v1.11 Device [SteelSeries Arctis Pro Wireless] on usb-0000:00:14.0-7.3.1.2/input1
[ 10.414296] usb 2-7.3: new SuperSpeed Gen 1 USB device number 5 using xhci_hcd
[ 10.437607] usb 2-7.3: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.26
[ 10.437612] usb 2-7.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 10.437615] usb 2-7.3: Product: USB3.1 Hub
[ 10.437618] usb 2-7.3: Manufacturer: GenesysLogic
[ 10.440722] hub 2-7.3:1.0: USB hub found
[ 10.441107] hub 2-7.3:1.0: 4 ports detected
[ 10.562089] usb 1-11: new high-speed USB device number 14 using xhci_hcd
[ 10.711721] usb 1-11: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
[ 10.711726] usb 1-11: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 10.711729] usb 1-11: Product: USB2.0 Hub
[ 10.714386] hub 1-11:1.0: USB hub found
[ 10.714738] hub 1-11:1.0: 4 ports detected
[ 10.790099] usb 1-7.2.5: new high-speed USB device number 15 using xhci_hcd
[ 10.890803] usb 1-7.2.5: New USB device found, idVendor=0451, idProduct=82ff, bcdDevice= 1.00
[ 10.890808] usb 1-7.2.5: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 10.890812] usb 1-7.2.5: SerialNumber: 13010071B15D
[ 10.894082] hid-generic 0003:0451:82FF.000A: hiddev4,hidraw7: USB HID v1.11 Device [HID 0451:82ff] on usb-0000:00:14.0-7.2.5/input0
[ 10.970084] usb 1-7.3.1.3: new full-speed USB device number 16 using xhci_hcd
[ 11.081560] usb 1-7.3.1.3: New USB device found, idVendor=1038, idProduct=1297, bcdDevice= 1.11
[ 11.081565] usb 1-7.3.1.3: New USB device strings: Mfr=3, Product=4, SerialNumber=0
[ 11.081568] usb 1-7.3.1.3: Product: Arctis Pro Wireless
[ 11.081571] usb 1-7.3.1.3: Manufacturer: SteelSeries
[ 11.098701] input: SteelSeries Arctis Pro Wireless Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7.3/1-7.3.1/1-7.3.1.3/1-7.3.1.3:1.3/0003:1038:1297.000B/input/input19
[ 11.158405] input: SteelSeries Arctis Pro Wireless as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7.3/1-7.3.1/1-7.3.1.3/1-7.3.1.3:1.3/0003:1038:1297.000B/input/input20
[ 11.159000] hid-generic 0003:1038:1297.000B: input,hiddev5,hidraw8: USB HID v1.11 Device [SteelSeries Arctis Pro Wireless] on usb-0000:00:14.0-7.3.1.3/input3
[ 11.198090] usb 1-12: new full-speed USB device number 17 using xhci_hcd
[ 11.360316] usb 1-12: New USB device found, idVendor=048d, idProduct=5702, bcdDevice= 0.01
[ 11.360321] usb 1-12: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 11.360324] usb 1-12: Product: ITE Device
[ 11.360327] usb 1-12: Manufacturer: ITE Tech. Inc.
[ 11.365615] hid-generic 0003:048D:5702.000C: hiddev6,hidraw9: USB HID v1.12 Device [ITE Tech. Inc. ITE Device] on usb-0000:00:14.0-12/input0
[ 11.490085] usb 1-14: new full-speed USB device number 18 using xhci_hcd
[ 11.640150] usb 1-14: New USB device found, idVendor=8087, idProduct=0026, bcdDevice= 0.02
[ 11.640155] usb 1-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 20.892047] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)
[ 21.015429] systemd[1]: Inserted module 'autofs4'
[ 21.041112] systemd[1]: Successfully credited entropy passed from boot loader.
[ 21.044191] systemd[1]: systemd 245.4-4ubuntu3.3pop0~1605124200~20.04~f505c79 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 21.062146] systemd[1]: Detected architecture x86-64.
[ 21.082634] systemd[1]: Set hostname to <pop-os>.
[ 21.139895] systemd[1]: /lib/systemd/system/dbus.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/dbus/system_bus_socket → /run/dbus/system_bus_socket; please update the unit file accordingly.
[ 21.173543] systemd[1]: cryptsetup.target: Found ordering cycle on [email protected]/start
[ 21.173544] systemd[1]: cryptsetup.target: Found dependency on systemd-random-seed.service/start
[ 21.173545] systemd[1]: cryptsetup.target: Found dependency on zfs-mount.service/start
[ 21.173546] systemd[1]: cryptsetup.target: Found dependency on zfs-load-module.service/start
[ 21.173547] systemd[1]: cryptsetup.target: Found dependency on cryptsetup.target/start
[ 21.173548] systemd[1]: cryptsetup.target: Job [email protected]/start deleted to break ordering cycle starting with cryptsetup.target/start
[ 21.173815] systemd[1]: Unnecessary job for /dev/disk/by-uuid/95306e17-6e4b-4d94-806c-54634e6d8013 was removed.
[ 21.174374] systemd[1]: Created slice Virtual Machine and Container Slice.
[ 21.174557] systemd[1]: Created slice system-modprobe.slice.
[ 21.174647] systemd[1]: Created slice Cryptsetup Units Slice.
[ 21.174760] systemd[1]: Created slice User and Session Slice.
[ 21.174783] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 21.174852] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 21.174869] systemd[1]: Reached target Block Device Preparation for /dev/mapper/cryptswap.
[ 21.174883] systemd[1]: Reached target User and Group Name Lookups.
[ 21.174890] systemd[1]: Reached target Slices.
[ 21.174899] systemd[1]: Reached target Libvirt guests shutdown.
[ 21.174931] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 21.174965] systemd[1]: Listening on LVM2 poll daemon socket.
[ 21.176975] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 21.177027] systemd[1]: Listening on Syslog Socket.
[ 21.177053] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 21.177122] systemd[1]: Listening on Journal Audit Socket.
[ 21.177156] systemd[1]: Listening on Journal Socket (/dev/log).
[ 21.177193] systemd[1]: Listening on Journal Socket.
[ 21.177231] systemd[1]: Listening on udev Control Socket.
[ 21.177261] systemd[1]: Listening on udev Kernel Socket.
[ 21.177609] systemd[1]: Mounting Huge Pages File System...
[ 21.177969] systemd[1]: Mounting POSIX Message Queue File System...
[ 21.178327] systemd[1]: Mounting RPC Pipe File System...
[ 21.178705] systemd[1]: Mounting Kernel Debug File System...
[ 21.179134] systemd[1]: Mounting Kernel Trace File System...
[ 21.179999] systemd[1]: Starting Journal Service...
[ 21.180367] systemd[1]: Starting Availability of block devices...
[ 21.180871] systemd[1]: Starting Set the console keyboard layout...
[ 21.181263] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 21.181647] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 21.181660] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 21.182032] systemd[1]: Started Nameserver information manager.
[ 21.182108] systemd[1]: Reached target Network (Pre).
[ 21.182671] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 21.183639] systemd[1]: Starting Load Kernel Modules...
[ 21.184043] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 21.184419] systemd[1]: Starting udev Coldplug all Devices...
[ 21.184797] systemd[1]: Starting Uncomplicated firewall...
[ 21.185540] systemd[1]: Mounted Huge Pages File System.
[ 21.185616] systemd[1]: Mounted POSIX Message Queue File System.
[ 21.185677] systemd[1]: Mounted Kernel Debug File System.
[ 21.185731] systemd[1]: Mounted Kernel Trace File System.
[ 21.185943] systemd[1]: Finished Availability of block devices.
[ 21.186166] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 21.186224] systemd[1]: Stopped target Block Device Preparation for /dev/mapper/cryptswap.
[ 21.186377] systemd[1]: Finished Uncomplicated firewall.
[ 21.189987] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro
[ 21.190026] RPC: Registered named UNIX socket transport module.
[ 21.190027] RPC: Registered udp transport module.
[ 21.190027] RPC: Registered tcp transport module.
[ 21.190027] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 21.190583] systemd[1]: Mounted RPC Pipe File System.
[ 21.190803] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 21.191098] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 21.191112] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 21.191495] systemd[1]: Starting Create System Users...
[ 21.193305] lp: driver loaded but no devices found
[ 21.194654] ppdev: user-space parallel port driver
[ 21.197461] systemd[1]: Finished Load Kernel Modules.
[ 21.197999] systemd[1]: Mounting FUSE Control File System...
[ 21.198402] systemd[1]: Mounting Kernel Configuration File System...
[ 21.198771] systemd[1]: Starting Apply Kernel Variables...
[ 21.199453] systemd[1]: Mounted FUSE Control File System.
[ 21.199514] systemd[1]: Mounted Kernel Configuration File System.
[ 21.199956] systemd[1]: Finished Create System Users.
[ 21.200336] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 21.205390] systemd[1]: Finished Apply Kernel Variables.
[ 21.205942] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 21.206398] systemd[1]: Starting udev Kernel Device Manager...
[ 21.211542] systemd[1]: Finished Set the console keyboard layout.
[ 21.229054] systemd[1]: Started Journal Service.
[ 21.232402] systemd-journald[614]: Received client request to flush runtime journal.
[ 21.285194] intel_pch_thermal 0000:00:12.0: enabling device (0000 -> 0002)
[ 21.294508] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[ 21.297759] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 21.297955] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 21.300127] Bluetooth: Core ver 2.22
[ 21.300134] NET: Registered protocol family 31
[ 21.300134] Bluetooth: HCI device and connection manager initialized
[ 21.300137] Bluetooth: HCI socket layer initialized
[ 21.300138] Bluetooth: L2CAP socket layer initialized
[ 21.300139] Bluetooth: SCO socket layer initialized
[ 21.304718] Intel(R) Wireless WiFi driver for Linux
[ 21.308060] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-56.ucode failed with error -2
[ 21.311021] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[ 21.311027] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 65.3.35.22
[ 21.311028] iwlwifi 0000:00:14.3: Found debug destination: EXTERNAL_DRAM
[ 21.311029] iwlwifi 0000:00:14.3: Found debug configuration: 0
[ 21.311182] iwlwifi 0000:00:14.3: loaded firmware version 55.d9698065.0 QuZ-a0-hr-b0-55.ucode op_mode iwlmvm
[ 21.311199] iwlwifi 0000:00:14.3: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
[ 21.327767] zlua: module license 'MIT' taints kernel.
[ 21.327768] Disabling lock debugging due to kernel taint
[ 21.342629] pstore: Using crash dump compression: deflate
[ 21.342643] pstore: Registered efi as persistent store backend
[ 21.343230] ee1004 0-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 21.343842] ee1004 0-0051: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 21.344420] ee1004 0-0052: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 21.345081] FAT-fs (nvme0n1p2): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 21.345520] FAT-fs (nvme0n1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 21.348293] mc: Linux media interface: v0.10
[ 21.349418] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 655360 ms ovfl timer
[ 21.349419] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 21.349419] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 21.349420] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 21.357059] snd_hda_intel 0000:00:1f.3: enabling device (0004 -> 0006)
[ 21.359417] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 21.360106] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x354
[ 21.389246] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC1220: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[ 21.389248] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 21.389248] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 21.389249] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 21.389249] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x1e/0x0
[ 21.389250] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 21.389250] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 21.389251] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 21.389251] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 21.391552] usbcore: registered new interface driver snd-usb-audio
[ 21.395465] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[ 21.415441] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[ 21.415464] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[ 21.415490] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[ 21.415509] input: HDA Intel PCH Line Out Front as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[ 21.415527] input: HDA Intel PCH Line Out Surround as /devices/pci0000:00/0000:00:1f.3/sound/card0/input25
[ 21.415552] input: HDA Intel PCH Line Out CLFE as /devices/pci0000:00/0000:00:1f.3/sound/card0/input26
[ 21.415569] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input27
[ 21.415588] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input28
[ 21.415609] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input29
[ 21.415626] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input30
[ 21.415644] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input31
[ 21.415661] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input32
[ 21.446441] usbcore: registered new interface driver btusb
[ 21.447401] Bluetooth: hci0: Firmware revision 0.0 build 188 week 26 2020
[ 21.534237] iwlwifi 0000:00:14.3: base HW address: f8:ac:65:1e:bc:6b
[ 21.546395] thermal thermal_zone3: failed to read out thermal zone (-61)
[ 21.547797] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
[ 21.966317] intel_rapl_common: Found RAPL domain package
[ 21.966318] intel_rapl_common: Found RAPL domain core
[ 21.966319] intel_rapl_common: Found RAPL domain uncore
[ 23.285199] ZFS: Loaded module v0.8.4-1ubuntu11, ZFS pool version 5000, ZFS filesystem version 5
[ 24.223568] zd0:
[ 24.225095] zd16: p1 p2 p3 p4
[ 24.225955] zd32: p1
[ 24.257518] audit: type=1400 audit(1606252179.950:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=33738 comm="apparmor_parser"
[ 24.257533] audit: type=1400 audit(1606252179.950:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=33739 comm="apparmor_parser"
[ 24.257856] audit: type=1400 audit(1606252179.950:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=33734 comm="apparmor_parser"
[ 24.257926] audit: type=1400 audit(1606252179.950:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ippusbxd" pid=33737 comm="apparmor_parser"
[ 24.258248] audit: type=1400 audit(1606252179.954:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=33740 comm="apparmor_parser"
[ 24.258250] audit: type=1400 audit(1606252179.954:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=33740 comm="apparmor_parser"
[ 24.258579] audit: type=1400 audit(1606252179.954:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oopslash" pid=33745 comm="apparmor_parser"
[ 24.258611] audit: type=1400 audit(1606252179.954:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=33736 comm="apparmor_parser"
[ 24.258612] audit: type=1400 audit(1606252179.954:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=33736 comm="apparmor_parser"
[ 24.258613] audit: type=1400 audit(1606252179.954:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=33736 comm="apparmor_parser"
[ 24.334136] Adding 4193784k swap on /dev/mapper/cryptswap. Priority:-2 extents:1 across:4193784k SSFS
[ 24.394739] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 24.394740] Bluetooth: BNEP filters: protocol multicast
[ 24.394742] Bluetooth: BNEP socket layer initialized
[ 24.398011] NET: Registered protocol family 38
[ 24.434126] pcieport 0000:00:1c.4: Intel SPT PCH root port ACS workaround enabled
[ 27.988288] igc 0000:06:00.0 enp6s0: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
[ 27.989500] IPv6: ADDRCONF(NETDEV_CHANGE): enp6s0: link becomes ready
[ 29.479006] e1000e 0000:00:1f.6 eno2: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None
[ 29.479149] IPv6: ADDRCONF(NETDEV_CHANGE): eno2: link becomes ready
[ 30.244947] wlo1: authenticate with e0:63:da:81:0a:c0
[ 30.246525] wlo1: send auth to e0:63:da:81:0a:c0 (try 1/3)
[ 30.271574] wlo1: authenticated
[ 30.274126] wlo1: associate with e0:63:da:81:0a:c0 (try 1/3)
[ 30.276053] wlo1: RX AssocResp from e0:63:da:81:0a:c0 (capab=0x11 status=0 aid=6)
[ 30.279526] wlo1: associated
[ 30.294279] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[ 32.121063] FS-Cache: Loaded
[ 32.133178] /dev/vmmon[34296]: Module vmmon: registered as misc device vmmon
[ 32.133179] /dev/vmmon[34296]: Using tsc_khz as TSC frequency: 3695998
[ 32.133180] /dev/vmmon[34296]: Module vmmon: initialized
[ 32.134205] FS-Cache: Netfs 'nfs' registered for caching
[ 32.140505] Guest personality initialized and is inactive
[ 32.140526] VMCI host device registered (name=vmci, major=10, minor=57)
[ 32.140526] Initialized host personality
[ 32.146481] NET: Registered protocol family 40
[ 32.204430] NFS: Registering the id_resolver key type
[ 32.204434] Key type id_resolver registered
[ 32.204435] Key type id_legacy registered
[ 32.542447] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 32.542877] virbr0: port 1(virbr0-nic) entered blocking state
[ 32.542877] virbr0: port 1(virbr0-nic) entered disabled state
[ 32.542908] device virbr0-nic entered promiscuous mode
[ 32.550489] bpfilter: Loaded bpfilter_umh pid 34453
[ 32.550531] Started bpfilter
[ 32.632163] virbr0: port 1(virbr0-nic) entered blocking state
[ 32.632164] virbr0: port 1(virbr0-nic) entered listening state
[ 32.646521] virbr0: port 1(virbr0-nic) entered disabled state
[ 33.240119] userif-6: sent link down event.
[ 33.240121] userif-6: sent link up event.
[ 34.028201] i915 0000:00:02.0: [drm] Reducing the compressed framebuffer size. This may lead to less power savings than a non-reduced-size. Try to increase stolen memory size if available in BIOS.
[ 34.961629] rfkill: input handler disabled
[ 41.564202] Bluetooth: RFCOMM TTY layer initialized
[ 41.564205] Bluetooth: RFCOMM socket layer initialized
[ 41.564207] Bluetooth: RFCOMM ver 1.11
[ 41.808719] rfkill: input handler enabled
[ 41.986247] pcieport 0000:00:1c.4: Intel SPT PCH root port ACS workaround enabled
[ 41.986349] pci 0000:07:00.0: [8086:15ea] type 01 class 0x060400
[ 41.986439] pci 0000:07:00.0: enabling Extended Tags
[ 41.986608] pci 0000:07:00.0: supports D1 D2
[ 41.986609] pci 0000:07:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 41.986763] pci 0000:07:00.0: PTM enabled, 4ns granularity
[ 41.986890] pci 0000:07:00.0: Adding to iommu group 9
[ 41.986954] pci 0000:07:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 41.987078] pci 0000:08:00.0: [8086:15ea] type 01 class 0x060400
[ 41.987171] pci 0000:08:00.0: enabling Extended Tags
[ 41.987330] pci 0000:08:00.0: supports D1 D2
[ 41.987331] pci 0000:08:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 41.987501] pci 0000:08:00.0: Adding to iommu group 9
[ 41.987544] pci 0000:08:01.0: [8086:15ea] type 01 class 0x060400
[ 41.987637] pci 0000:08:01.0: enabling Extended Tags
[ 41.987794] pci 0000:08:01.0: supports D1 D2
[ 41.987794] pci 0000:08:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 41.987957] pci 0000:08:01.0: Adding to iommu group 9
[ 41.988001] pci 0000:08:02.0: [8086:15ea] type 01 class 0x060400
[ 41.988093] pci 0000:08:02.0: enabling Extended Tags
[ 41.988247] pci 0000:08:02.0: supports D1 D2
[ 41.988247] pci 0000:08:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 41.988438] pci 0000:08:02.0: Adding to iommu group 9
[ 41.988486] pci 0000:08:04.0: [8086:15ea] type 01 class 0x060400
[ 41.988579] pci 0000:08:04.0: enabling Extended Tags
[ 41.988746] pci 0000:08:04.0: supports D1 D2
[ 41.988747] pci 0000:08:04.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 41.988910] pci 0000:08:04.0: Adding to iommu group 9
[ 41.988991] pci 0000:07:00.0: PCI bridge to [bus 08-3f]
[ 41.989000] pci 0000:07:00.0: bridge window [io 0x0000-0x0fff]
[ 41.989005] pci 0000:07:00.0: bridge window [mem 0x00000000-0x000fffff]
[ 41.989013] pci 0000:07:00.0: bridge window [mem 0x00000000-0x000fffff 64bit pref]
[ 41.989016] pci 0000:08:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 41.989027] pci 0000:08:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 41.989037] pci 0000:08:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 41.989047] pci 0000:08:04.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 41.989159] pci 0000:09:00.0: [8086:15eb] type 00 class 0x088000
[ 41.989199] pci 0000:09:00.0: reg 0x10: [mem 0x00000000-0x0003ffff]
[ 41.989212] pci 0000:09:00.0: reg 0x14: [mem 0x00000000-0x00000fff]
[ 41.989273] pci 0000:09:00.0: enabling Extended Tags
[ 41.989417] pci 0000:09:00.0: supports D1 D2
[ 41.989417] pci 0000:09:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 41.989594] pci 0000:09:00.0: Adding to iommu group 9
[ 41.989709] pci 0000:08:00.0: PCI bridge to [bus 09-3f]
[ 41.989717] pci 0000:08:00.0: bridge window [io 0x0000-0x0fff]
[ 41.989721] pci 0000:08:00.0: bridge window [mem 0x00000000-0x000fffff]
[ 41.989730] pci 0000:08:00.0: bridge window [mem 0x00000000-0x000fffff 64bit pref]
[ 41.989731] pci_bus 0000:09: busn_res: [bus 09-3f] end is updated to 09
[ 41.989824] pci 0000:08:01.0: PCI bridge to [bus 0a-3f]
[ 41.989832] pci 0000:08:01.0: bridge window [io 0x0000-0x0fff]
[ 41.989837] pci 0000:08:01.0: bridge window [mem 0x00000000-0x000fffff]
[ 41.989845] pci 0000:08:01.0: bridge window [mem 0x00000000-0x000fffff 64bit pref]
[ 41.989846] pci_bus 0000:0a: busn_res: [bus 0a-3f] end is updated to 0a
[ 41.989967] pci 0000:0b:00.0: [8086:15ec] type 00 class 0x0c0330
[ 41.990010] pci 0000:0b:00.0: reg 0x10: [mem 0x00000000-0x0000ffff]
[ 41.990093] pci 0000:0b:00.0: enabling Extended Tags
[ 41.990252] pci 0000:0b:00.0: supports D1 D2
[ 41.990252] pci 0000:0b:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 41.990398] pci 0000:0b:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:08:02.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[ 41.990477] pci 0000:0b:00.0: Adding to iommu group 9
[ 41.990603] pci 0000:08:02.0: PCI bridge to [bus 0b-3f]
[ 41.990612] pci 0000:08:02.0: bridge window [io 0x0000-0x0fff]
[ 41.990616] pci 0000:08:02.0: bridge window [mem 0x00000000-0x000fffff]
[ 41.990624] pci 0000:08:02.0: bridge window [mem 0x00000000-0x000fffff 64bit pref]
[ 41.990624] pci_bus 0000:0b: busn_res: [bus 0b-3f] end is updated to 0b
[ 41.990715] pci 0000:08:04.0: PCI bridge to [bus 0c-3f]
[ 41.990723] pci 0000:08:04.0: bridge window [io 0x0000-0x0fff]
[ 41.990727] pci 0000:08:04.0: bridge window [mem 0x00000000-0x000fffff]
[ 41.990734] pci 0000:08:04.0: bridge window [mem 0x00000000-0x000fffff 64bit pref]
[ 41.990735] pci_bus 0000:0c: busn_res: [bus 0c-3f] end is updated to 0c
[ 41.990738] pci_bus 0000:08: busn_res: [bus 08-3f] end is updated to 0c
[ 41.990743] pci_bus 0000:08: Allocating resources
[ 41.990768] pci 0000:08:01.0: bridge window [io 0x1000-0x0fff] to [bus 0a] add_size 1000
[ 41.990769] pci 0000:08:01.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 0a] add_size 200000 add_align 100000
[ 41.990769] pci 0000:08:01.0: bridge window [mem 0x00100000-0x000fffff] to [bus 0a] add_size 200000 add_align 100000
[ 41.990770] pci 0000:08:04.0: bridge window [io 0x1000-0x0fff] to [bus 0c] add_size 1000
[ 41.990771] pci 0000:08:04.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 0c] add_size 200000 add_align 100000
[ 41.990771] pci 0000:08:04.0: bridge window [mem 0x00100000-0x000fffff] to [bus 0c] add_size 200000 add_align 100000
[ 41.990772] pci 0000:07:00.0: bridge window [io 0x1000-0x0fff] to [bus 08-0c] add_size 3000
[ 41.990773] pci 0000:07:00.0: bridge window [mem 0x00100000-0x002fffff 64bit pref] to [bus 08-0c] add_size 400000 add_align 100000
[ 41.990774] pci 0000:07:00.0: bridge window [mem 0x00100000-0x004fffff] to [bus 08-0c] add_size 400000 add_align 100000
[ 41.990776] pci 0000:07:00.0: BAR 14: assigned [mem 0x9c000000-0x9c7fffff]
[ 41.990777] pci 0000:07:00.0: BAR 15: assigned [mem 0x94000000-0x945fffff 64bit pref]
[ 41.990777] pci 0000:07:00.0: BAR 13: no space for [io size 0x3000]
[ 41.990778] pci 0000:07:00.0: BAR 13: failed to assign [io size 0x3000]
[ 41.990779] pci 0000:07:00.0: BAR 13: no space for [io size 0x3000]
[ 41.990779] pci 0000:07:00.0: BAR 13: failed to assign [io size 0x3000]
[ 41.990781] pci 0000:08:00.0: BAR 14: assigned [mem 0x9c000000-0x9c0fffff]
[ 41.990781] pci 0000:08:01.0: BAR 14: assigned [mem 0x9c100000-0x9c2fffff]
[ 41.990782] pci 0000:08:01.0: BAR 15: assigned [mem 0x94000000-0x941fffff 64bit pref]
[ 41.990783] pci 0000:08:02.0: BAR 14: assigned [mem 0x9c300000-0x9c3fffff]
[ 41.990783] pci 0000:08:04.0: BAR 14: assigned [mem 0x9c400000-0x9c5fffff]
[ 41.990784] pci 0000:08:04.0: BAR 15: assigned [mem 0x94200000-0x943fffff 64bit pref]
[ 41.990784] pci 0000:08:01.0: BAR 13: no space for [io size 0x1000]
[ 41.990785] pci 0000:08:01.0: BAR 13: failed to assign [io size 0x1000]
[ 41.990785] pci 0000:08:04.0: BAR 13: no space for [io size 0x1000]
[ 41.990786] pci 0000:08:04.0: BAR 13: failed to assign [io size 0x1000]
[ 41.990787] pci 0000:08:04.0: BAR 13: no space for [io size 0x1000]
[ 41.990787] pci 0000:08:04.0: BAR 13: failed to assign [io size 0x1000]
[ 41.990787] pci 0000:08:01.0: BAR 13: no space for [io size 0x1000]
[ 41.990788] pci 0000:08:01.0: BAR 13: failed to assign [io size 0x1000]
[ 41.990789] pci 0000:09:00.0: BAR 0: assigned [mem 0x9c000000-0x9c03ffff]
[ 41.990798] pci 0000:09:00.0: BAR 1: assigned [mem 0x9c040000-0x9c040fff]
[ 41.990802] pci 0000:08:00.0: PCI bridge to [bus 09]
[ 41.990809] pci 0000:08:00.0: bridge window [mem 0x9c000000-0x9c0fffff]
[ 41.990821] pci 0000:08:01.0: PCI bridge to [bus 0a]
[ 41.990827] pci 0000:08:01.0: bridge window [mem 0x9c100000-0x9c2fffff]
[ 41.990831] pci 0000:08:01.0: bridge window [mem 0x94000000-0x941fffff 64bit pref]
[ 41.990839] pci 0000:0b:00.0: BAR 0: assigned [mem 0x9c300000-0x9c30ffff]
[ 41.990845] pci 0000:08:02.0: PCI bridge to [bus 0b]
[ 41.990851] pci 0000:08:02.0: bridge window [mem 0x9c300000-0x9c3fffff]
[ 41.990862] pci 0000:08:04.0: PCI bridge to [bus 0c]
[ 41.990869] pci 0000:08:04.0: bridge window [mem 0x9c400000-0x9c5fffff]
[ 41.990873] pci 0000:08:04.0: bridge window [mem 0x94200000-0x943fffff 64bit pref]
[ 41.990881] pci 0000:07:00.0: PCI bridge to [bus 08-0c]
[ 41.990887] pci 0000:07:00.0: bridge window [mem 0x9c000000-0x9c7fffff]
[ 41.990892] pci 0000:07:00.0: bridge window [mem 0x94000000-0x945fffff 64bit pref]
[ 41.990919] pcieport 0000:07:00.0: enabling device (0000 -> 0002)
[ 41.991058] pcieport 0000:07:00.0: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise- Interlock- NoCompl+ IbPresDis- LLActRep-
[ 41.991106] pcieport 0000:07:00.0: pciehp: Slot(0): Card not present
[ 41.991636] pcieport 0000:08:00.0: can't change power state from D3hot to D0 (config space inaccessible)
[ 41.993967] pcieport 0000:08:01.0: can't change power state from D3hot to D0 (config space inaccessible)
[ 41.994143] pcieport 0000:08:01.0: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise- Interlock- NoCompl+ IbPresDis- LLActRep-
[ 41.994497] pcieport 0000:08:02.0: can't change power state from D3hot to D0 (config space inaccessible)
[ 41.994613] pcieport 0000:08:04.0: can't change power state from D3hot to D0 (config space inaccessible)
[ 41.994825] pcieport 0000:08:04.0: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise- Interlock- NoCompl+ IbPresDis- LLActRep-
[ 41.994978] thunderbolt 0000:09:00.0: can't change power state from D3hot to D0 (config space inaccessible)
[ 41.995124] thunderbolt 0000:09:00.0: unexpected hop count: 1023
[ 41.995345] thunderbolt 0000:09:00.0: cannot enable MSI, aborting
[ 41.995573] thunderbolt: probe of 0000:09:00.0 failed with error -28
[ 41.995576] pci 0000:0b:00.0: can't change power state from D3hot to D0 (config space inaccessible)
[ 41.995724] xhci_hcd 0000:0b:00.0: can't change power state from D3hot to D0 (config space inaccessible)
[ 41.995941] xhci_hcd 0000:0b:00.0: xHCI Host Controller
[ 41.995971] xhci_hcd 0000:0b:00.0: new USB bus registered, assigned bus number 3
[ 41.996007] xhci_hcd 0000:0b:00.0: Host halt failed, -19
[ 41.996008] xhci_hcd 0000:0b:00.0: can't setup: -19
[ 41.996010] xhci_hcd 0000:0b:00.0: USB bus 3 deregistered
[ 41.996209] xhci_hcd 0000:0b:00.0: init 0000:0b:00.0 fail, -19
[ 41.996358] pci_bus 0000:0c: busn_res: [bus 0c] is released
[ 41.996408] pci 0000:08:04.0: Removing from iommu group 9
[ 41.996929] pci 0000:0b:00.0: Removing from iommu group 9
[ 41.996941] pci_bus 0000:0b: busn_res: [bus 0b] is released
[ 41.997009] pci 0000:08:02.0: Removing from iommu group 9
[ 41.997198] pci_bus 0000:0a: busn_res: [bus 0a] is released
[ 41.997252] pci 0000:08:01.0: Removing from iommu group 9
[ 41.997547] pci 0000:09:00.0: Removing from iommu group 9
[ 41.997560] pci_bus 0000:09: busn_res: [bus 09] is released
[ 41.997598] pci 0000:08:00.0: Removing from iommu group 9
[ 44.185603] exfat: Deprecated parameter 'namecase'
[ 44.186693] exfat: Deprecated parameter 'namecase'
[ 44.201732] rfkill: input handler disabled
[ 45.902366] show_signal_msg: 20 callbacks suppressed
[ 45.902367] nautilus[36234]: segfault at 20 ip 00007f079c4d9214 sp 00007ffcbfd22758 error 4 in libgio-2.0.so.0.6400.3[7f079c42b000+113000]
[ 45.902373] Code: 74 0c 31 d2 31 f6 e9 ab 80 02 00 0f 1f 00 c3 0f 1f 80 00 00 00 00 f3 0f 1e fa 48 8b 07 c3 0f 1f 84 00 00 00 00 00 f3 0f 1e fa <48> 8b 47 20 c3 0f 1f 80 00 00 00 00 f3 0f 1e fa 55 48 83 ec 10 48
[ 61.768564] logitech-hidpp-device 0003:046D:4082.0004: HID++ 4.5 device connected.
[ 64.984658] audit: type=1400 audit(1606252220.419:32): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libvirt-094a6af6-cb68-4af7-ab0b-78be553a0fdf" pid=37167 comm="apparmor_parser"
[ 65.114662] audit: type=1400 audit(1606252220.546:33): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-094a6af6-cb68-4af7-ab0b-78be553a0fdf" pid=37170 comm="apparmor_parser"
[ 65.221446] audit: type=1400 audit(1606252220.652:34): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-094a6af6-cb68-4af7-ab0b-78be553a0fdf" pid=37174 comm="apparmor_parser"
[ 65.327996] audit: type=1400 audit(1606252220.755:35): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="libvirt-094a6af6-cb68-4af7-ab0b-78be553a0fdf" pid=37178 comm="apparmor_parser"
[ 65.342584] virbr0: port 2(vnet0) entered blocking state
[ 65.342585] virbr0: port 2(vnet0) entered disabled state
[ 65.342640] device vnet0 entered promiscuous mode
[ 65.342799] virbr0: port 2(vnet0) entered blocking state
[ 65.342800] virbr0: port 2(vnet0) entered listening state
[ 65.451876] audit: type=1400 audit(1606252220.881:36): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="libvirt-094a6af6-cb68-4af7-ab0b-78be553a0fdf" pid=37197 comm="apparmor_parser"
[ 65.545714] userif-6: sent link down event.
[ 65.545714] userif-6: sent link up event.
[ 67.388148] virbr0: port 2(vnet0) entered learning state
[ 69.284645] vfio-pci 0000:01:00.0: enabling device (0000 -> 0003)
[ 69.285150] vfio-pci 0000:01:00.0: vfio_ecap_init: hiding ecap 0x19@0x900
[ 69.308837] vfio-pci 0000:01:00.1: enabling device (0000 -> 0002)
[ 69.421674] virbr0: port 2(vnet0) entered forwarding state
[ 69.421677] virbr0: topology change detected, propagating
[ 69.623650] userif-6: sent link down event.
[ 69.623651] userif-6: sent link up event.
[ 87.066045] pci_bus 0000:08: busn_res: [bus 08-0c] is released
[ 87.066321] pci 0000:07:00.0: Removing from iommu group 9
[ 2274.431884] virbr0: port 2(vnet0) entered disabled state
[ 2274.433499] device vnet0 left promiscuous mode
[ 2274.433501] virbr0: port 2(vnet0) entered disabled state
[ 2274.631767] userif-6: sent link down event.
[ 2274.631771] userif-6: sent link up event.
[ 2277.208501] audit: type=1400 audit(1606254432.573:37): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="libvirt-094a6af6-cb68-4af7-ab0b-78be553a0fdf" pid=370362 comm="apparmor_parser"
[ 2277.220082] zd32: p1
[ 2277.230704] zd16: p1 p2 p3 p4
[ 2277.237350] zd16: p1 p2 p3 p4
[ 2277.238753] zd32: p1
and here is my kvm xml
<domain type="kvm">
<name>win10</name>
<uuid>094a6af6-cb68-4af7-ab0b-78be553a0fdf</uuid>
<metadata>
<libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
<libosinfo:os id="http://microsoft.com/win/10"/>
</libosinfo:libosinfo>
</metadata>
<memory unit="KiB">24576000</memory>
<currentMemory unit="KiB">24576000</currentMemory>
<vcpu placement="static">12</vcpu>
<os>
<type arch="x86_64" machine="pc-q35-4.2">hvm</type>
<loader readonly="yes" type="pflash">/usr/share/OVMF/OVMF_CODE.fd</loader>
<nvram>/var/lib/libvirt/qemu/nvram/win10_VARS.fd</nvram>
</os>
<features>
<acpi/>
<apic/>
<hyperv>
<relaxed state="on"/>
<vapic state="on"/>
<spinlocks state="on" retries="8191"/>
<vendor_id state="on" value="randomid"/>
</hyperv>
<kvm>
<hidden state="on"/>
</kvm>
<vmport state="off"/>
</features>
<cpu mode="host-passthrough" check="partial">
<topology sockets="1" cores="6" threads="2"/>
</cpu>
<clock offset="localtime">
<timer name="rtc" tickpolicy="catchup"/>
<timer name="pit" tickpolicy="delay"/>
<timer name="hpet" present="no"/>
<timer name="hypervclock" present="yes"/>
</clock>
<on_poweroff>destroy</on_poweroff>
<on_reboot>restart</on_reboot>
<on_crash>destroy</on_crash>
<pm>
<suspend-to-mem enabled="no"/>
<suspend-to-disk enabled="no"/>
</pm>
<devices>
<emulator>/usr/bin/qemu-system-x86_64</emulator>
<disk type="file" device="cdrom">
<driver name="qemu" type="raw"/>
<source file="/home/anonymous/Downloads/Win10_2004_English_x64.iso"/>
<target dev="sda" bus="sata"/>
<readonly/>
<address type="drive" controller="0" bus="0" target="0" unit="0"/>
</disk>
<source file="/home/anonymous/Downloads/virtio-win-0.1.185.iso"/>
<target dev="sdb" bus="sata"/>
<readonly/>
<address type="drive" controller="0" bus="0" target="0" unit="1"/>
</disk>
<disk type="block" device="disk">
<driver name="qemu" type="raw" cache="none" io="native"/>
<source dev="/dev/zvol/zvols/windows"/>
<target dev="vda" bus="virtio"/>
<boot order="1"/>
<address type="pci" domain="0x0000" bus="0x04" slot="0x00" function="0x0"/>
</disk>
<source dev="/dev/zvol/zvols/vnvm-windows"/>
<target dev="vdb" bus="virtio"/>
<address type="pci" domain="0x0000" bus="0x09" slot="0x00" function="0x0"/>
</disk>
<controller type="usb" index="0" model="qemu-xhci" ports="15">
<address type="pci" domain="0x0000" bus="0x02" slot="0x00" function="0x0"/>
</controller>
<controller type="sata" index="0">
<address type="pci" domain="0x0000" bus="0x00" slot="0x1f" function="0x2"/>
</controller>
<controller type="pci" index="0" model="pcie-root"/>
<controller type="pci" index="1" model="pcie-root-port">
<model name="pcie-root-port"/>
<target chassis="1" port="0x10"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x0" multifunction="on"/>
</controller>
<controller type="pci" index="2" model="pcie-root-port">
<target chassis="2" port="0x11"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x1"/>
</controller>
<controller type="pci" index="3" model="pcie-root-port">
<target chassis="3" port="0x12"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x2"/>
</controller>
<controller type="pci" index="4" model="pcie-root-port">
<target chassis="4" port="0x13"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x3"/>
</controller>
<controller type="pci" index="5" model="pcie-root-port">
<target chassis="5" port="0x14"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x4"/>
</controller>
<controller type="pci" index="6" model="pcie-root-port">
<target chassis="6" port="0x15"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x5"/>
</controller>
<controller type="pci" index="7" model="pcie-root-port">
<target chassis="7" port="0x8"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x0" multifunction="on"/>
</controller>
<controller type="pci" index="8" model="pcie-root-port">
<target chassis="8" port="0x9"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x1"/>
</controller>
<controller type="pci" index="9" model="pcie-root-port">
<target chassis="9" port="0xa"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x2"/>
</controller>
<controller type="virtio-serial" index="0">
<address type="pci" domain="0x0000" bus="0x03" slot="0x00" function="0x0"/>
</controller>
<interface type="network">
<mac address="52:54:00:c8:97:f6"/>
<source network="default"/>
<model type="e1000e"/>
<address type="pci" domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
</interface>
<serial type="pty">
<target type="isa-serial" port="0">
<model name="isa-serial"/>
</target>
</serial>
<console type="pty">
<target type="serial" port="0"/>
</console>
<input type="mouse" bus="ps2"/>
<input type="keyboard" bus="ps2"/>
<hostdev mode="subsystem" type="pci" managed="yes">
<source>
<address domain="0x0000" bus="0x02" slot="0x00" function="0x0"/>
</source>
<address type="pci" domain="0x0000" bus="0x06" slot="0x00" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
</source>
<address type="pci" domain="0x0000" bus="0x07" slot="0x00" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x01" slot="0x00" function="0x1"/>
</source>
<address type="pci" domain="0x0000" bus="0x08" slot="0x00" function="0x0"/>
</hostdev>
<redirdev bus="usb" type="spicevmc">
<address type="usb" bus="0" port="2"/>
</redirdev>
<address type="usb" bus="0" port="3"/>
</redirdev>
<memballoon model="virtio">
<address type="pci" domain="0x0000" bus="0x05" slot="0x00" function="0x0"/>
</memballoon>
</devices>
</domain>
does anyone know what could be causing this?
I tried to add as a pastebin link, but it says links aren’t allowed, and I don’t understand how formatting works on this forum software, so it 's kind of just a big blob… sorry about that.
