Hello all,
I’m looking for advice on tuning and performance enhancing for VFIO (2 Machines, 1 CPU) sort. I have a working setup, with Fedora 34, following the guides here on level1. https://forum.level1techs.com/t/fedora-33-ultimiate-vfio-guide-for-2020-2021-wip/163814/4 and I’, seeing rather intense stuttering and almost unplayable gaming play at times, not all the time, just some of the time. Below is a list of the hardware/software and general layout.
Hardware:Entire Build listed: heller64bit - Saved Part Lists - PCPartPicker
Host Hardware:
-Samsung 970 Evo 1TB (Fedora 34 Linux)
-GTX 1080 Turbo is the Host (Linux) GPU.
-Gigabyte TRX40 Aorus Master EATX MOBO
-G.Skill 4x32GB DDR4-3600 CL18 RAM
Windows Guest Passtrhough:
-32GB Allocated to the VM.
-Onboard Intel GiB NIC
-XFX 6800XT
-PCIe USB card (for native USB plug-n-play)
-Sabrent Rocket 4 Plus (Native install of windows)
Software:-Fedora 34 Linux-VFIO (Virtual Function I/O, Native built-in)
-KVM (Kernel Virtual Machine, built-in to the Linux Kernel)
-QEMU (Open-source Hypervisor, CLI)-Libvirt (Open Source API to manage hypervisors, like QEMU, VMWare, etc…)
-Virt-Manager (GUI Application to manage all the above software pieces.)
Below is the XML, I’ve not set CPU pinning as it doesn’t seam to help.
<metadata>
<libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
<libosinfo:os id="http://microsoft.com/win/10"/>
</libosinfo:libosinfo>
</metadata>
<memory unit="KiB">33554432</memory>
<currentMemory unit="KiB">33554432</currentMemory>
<vcpu placement="static">12</vcpu>
<os>
<type arch="x86_64" machine="pc-q35-5.2">hvm</type>
<loader readonly="yes" type="pflash">/usr/share/edk2/ovmf/OVMF_CODE.fd</loader>
<nvram>/var/lib/libvirt/qemu/nvram/win10-2_VARS.fd</nvram>
<boot dev="hd"/>
<bootmenu enable="yes"/>
</os>
<features>
<acpi/>
<apic/>
<hyperv>
<relaxed state="on"/>
<vapic state="on"/>
<spinlocks state="on" retries="8191"/>
</hyperv>
<vmport state="off"/>
</features>
<cpu mode="host-model" check="partial">
<topology sockets="1" dies="1" cores="6" threads="2"/>
</cpu>
<clock offset="localtime">
<timer name="rtc" tickpolicy="catchup"/>
<timer name="pit" tickpolicy="delay"/>
<timer name="hpet" present="no"/>
<timer name="hypervclock" present="yes"/>
</clock>
<on_poweroff>destroy</on_poweroff>
<on_reboot>restart</on_reboot>
<on_crash>destroy</on_crash>
<pm>
<suspend-to-mem enabled="no"/>
<suspend-to-disk enabled="no"/>
</pm>
<devices>
<emulator>/usr/bin/qemu-system-x86_64</emulator>
<disk type="file" device="disk">
<driver name="qemu" type="qcow2"/>
<source file="/var/lib/libvirt/images/win10-2.qcow2"/>
<target dev="sda" bus="sata"/>
<address type="drive" controller="0" bus="0" target="0" unit="0"/>
</disk>
<disk type="block" device="disk">
<driver name="qemu" type="raw" cache="writeback"/>
<source dev="/dev/sdb"/>
<target dev="hda" bus="sata"/>
<address type="drive" controller="0" bus="0" target="0" unit="4"/>
</disk>
