VFIO PCIe USB cards for Passthrough - my experince -
Dear LevelOneTechs users,
I would like to share with you my experiences on VFIO USB passthrough, hoping could be useful for all of us.
My system consist of
  • ASUS Crosshair Hero VII
  • CPU AMD 3900X
  • 64GB RAM
  • I350 Ethernet Controller
  • UBUNTU 20.04 LTS
  • I run KVM and 4 VMs:
    – Compiled against library: libvirt 6.0.0
    – Using library: libvirt 6.0.0
    – Using API: QEMU 6.0.0
    – Running hypervisor: QEMU 4.2.1
I decided to buy a PCIE USB card to passthrough one USB port to each VM.
One of the main reason I decided to dedicate an USB port to a VM is to avoid audio crackling when using videoconference tools and more in general audio tools in VMs.
  1. The experience with Sonnett
In September 2020, after reading a lot on various forums I decided to buy a pcie usb card Sonnett USB3-PRO-4P10-E however I experienced a basic issue: when I try to connect devices to the USB ports managed by the ASM2142 controllers of the PCIE card, the devices are not detected.
Then I opened a case with Sonnett tech support and after a tech deep dive they found a compatibility issue with the Asus CH7 mainboard, at least.
This situation is “documented”, and you can check Sonnett web site for the specific USB card, look at notes.
Even if Sonnett would had solved the fundamental problem of usb device detection another blocking problem was present anyway: The IOMMU grouping was not good to perform USB passthrough, both the ASM2142 controllers were in the same IOMMU group!
Just to give a more complete information I tested the USB card with Asus CH7 BIOS version 3103, Kernel 5.4.0-37-generic and the IOMMU grouping was this:
You can see a couple of ASMEDIA controllers under IOMMU group 18:
IOMMU group 18
02:00.0 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Device [1022:43d0] (rev 01)
02:00.1 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset SATA Controller [1022:43c8] (rev 01)
02:00.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Bridge [1022:43c6] (rev 01)
03:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port [1022:43c7] (rev 01)
03:01.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port [1022:43c7] (rev 01)
03:02.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port [1022:43c7] (rev 01)
03:03.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port [1022:43c7] (rev 01)
03:04.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port [1022:43c7] (rev 01)
03:09.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port [1022:43c7] (rev 01)
06:00.0 Ethernet controller [0200]: Intel Corporation I211 Gigabit Network Connection [8086:1539] (rev 03)
08:00.0 PCI bridge [0604]: Pericom Semiconductor Device [12d8:2308]
09:01.0 PCI bridge [0604]: Pericom Semiconductor Device [12d8:2308]
09:02.0 PCI bridge [0604]: Pericom Semiconductor Device [12d8:2308]
0a:00.0 USB controller [0c03]: ASMedia Technology Inc. ASM2142 USB 3.1 Host Controller [1b21:2142]
0b:00.0 USB controller [0c03]: ASMedia Technology Inc. ASM2142 USB 3.1 Host Controller [1b21:2142]
I had then send back the usb card to Amazon: Thanks Amazon for your support! A very different one support from Asus, as you will see in the following.
  1. The experience with Asus support
I have wrote to Asus Support explaining the above issue, but I didn’t have get back any answer!
Asus didn’t support me at all!
  1. The second experience with Sonnett
In June 2021 I decided to try to buy the same Sonnett PCIE USB card but the usb-c model (USB3C-4PM-E) to test it with a newer BIOS version of my mainboard, the 4301.
But the situation found have been the same of the USB3-PRO-4P10-E card.
In this scenario the IOMMU grouping was this:
IOMMU Group 0:
00:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 1:
00:01.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
IOMMU Group 10:
00:07.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
IOMMU Group 11:
00:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 12:
00:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
IOMMU Group 13:
00:14.0 SMBus [0c05]: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller [1022:790b] (rev 61)
00:14.3 ISA bridge [0601]: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge [1022:790e] (rev 51)
IOMMU Group 14:
00:18.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 0 [1022:1440]
00:18.1 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 1 [1022:1441]
00:18.2 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 2 [1022:1442]
00:18.3 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 3 [1022:1443]
00:18.4 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 4 [1022:1444]
00:18.5 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 5 [1022:1445]
00:18.6 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 6 [1022:1446]
00:18.7 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 7 [1022:1447]
IOMMU Group 15:
01:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983 [144d:a808]
IOMMU group 16
0c:00.0 USB controller [0c03]: ASMedia Technology Inc. ASM2142 USB 3.1 Host Controller [1b21:2142]
IOMMU Group 17:
0f:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP107 [GeForce GTX 1050 Ti] [10de:1c82] (rev a1)
0f:00.1 Audio device [0403]: NVIDIA Corporation GP107GL High Definition Audio Controller [10de:0fb9] (rev a1)
IOMMU Group 18:
10:00.0 Ethernet controller [0200]: Intel Corporation I350 Gigabit Network Connection [8086:1521] (rev 01)
IOMMU Group 19:
10:00.1 Ethernet controller [0200]: Intel Corporation I350 Gigabit Network Connection [8086:1521] (rev 01)
IOMMU Group 2:
00:01.3 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
IOMMU Group 20:
10:00.2 Ethernet controller [0200]: Intel Corporation I350 Gigabit Network Connection [8086:1521] (rev 01)
IOMMU Group 21:
10:00.3 Ethernet controller [0200]: Intel Corporation I350 Gigabit Network Connection [8086:1521] (rev 01)
IOMMU Group 22:
12:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function [1022:148a]
IOMMU Group 23:
13:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
IOMMU Group 24:
13:00.1 Encryption controller [1080]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP [1022:1486]
IOMMU Group 25:
13:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller [1022:149c]
IOMMU Group 26:
13:00.4 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller [1022:1487]
IOMMU Group 27:
10:10.0 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
IOMMU Group 28:
10:10.4 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
IOMMU Group 29:
10:11.0 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
IOMMU Group 3:
00:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 30:
10:11.4 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
IOMMU Group 31:
10:10.1 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
IOMMU Group 32:
10:10.5 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
IOMMU Group 33:
10:11.1 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
IOMMU Group 34:
10:11.5 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
IOMMU Group 35:
10:10.2 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
IOMMU Group 36:
10:10.6 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
IOMMU Group 37:
10:11.2 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
IOMMU Group 38:
10:11.6 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
IOMMU Group 39:
10:10.3 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
IOMMU Group 4:
00:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 40:
10:10.7 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
IOMMU Group 41:
10:11.3 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
IOMMU Group 42:
10:11.7 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
IOMMU Group 5:
00:03.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
IOMMU Group 6:
00:03.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
IOMMU Group 7:
00:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 8:
00:05.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 9:
00:07.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
Note 1) I obtained a good IOMMU grouping the my Intel I350 network controller and for my graphic card but not for the StarTech USB Card!
I had then send back the usb card to Amazon: Thanks again Amazon for your support!
  1. The experience with HighPoint
In June 2021 I decided to test a different brand PCIE USB card, an HighPoint one and I was interested in: HighPoint 4 Port RocketU 1344A or the RocketU 1244A.
I contacted then the HighPoint pre sales tech support.
Below the email I have had sent them:
Dear HighPoint tech staff,
I’m writing you to kindly ask for your support before buy one of your PCIE USB card.
I use linux Ubuntu 20.04 LTS and KVM as virtualization layer.
I use linux on the Host computer where kvm run and Linux on the guest VMs too.
I need to assign a dedicated usb controllers to a linux VMs.
In the past I deeply tested all the Allegro Pro card without any success: Sonnet added a tech note on their USB card after my test in collaboration with Sonnet support.
What I need:
One PCIE USB card with VFIO support without the use of linux kernel parameter “pci=disable_acs_redir=pci:12c4:1234” to disables PCI Express Access Control Services (ACS) functions ACS P2P Request Redirect and ACS P2P Completion Redirect.
I need the card to have usb controllers supporting “really” the RESET signal. I stressed this point too because, for instance, this review to RocketU RU1144D on Amazon leaves me in doubt:
Look on Amazon site for HighPoint-RocketU-1144D-Express-Adapter and go to read the Conner Helton review.
Do you have a card supporting linux vfio without the above kernel parameters and can be arranged in different IOMMU groups?
Many thanks for your support.
Kind regards,
XYZ
During the email exchange it seemed to me that Sonnett engineering listened carefully to my arguments and asked pertinent questions. They said they were busy reproducing a useful configuration to get them to respond to my request. After a couple of weeks they wrote me with this sentence: we tested the PCIE USB product and found that our product cannot support the use of KVM on Ubuntu 20.04.2 and we can support the normal use of KVM on Redhat.
I’m honestly not sure I understood the answer… left me puzzled…
I don’t know what to think about HighPoint support!?
  1. The experience with StarTech
At this point I was a bit frustrated… however I have decided to perform one more test with a different brand usb card, the StarTech PEXUSB3S44V. In bought the card in July 2021.
The operation of the StarTech card is better than the Sonnett usb cards, the usb attached devices are detected and working as expected, however the IOMMU grouping doesn’t let me perform the usb passtrought: all the uPD720202 USB 3.0 Host controller are in the same IOMMU Group, the 16!
Just to give a more complete information I say that I tested the USB card with the BIOS version 4301 and 4402 and the Kernel 5.8.18-050818-generic.
IOMMU Group 0:
IOMMU Group 1:
IOMMU Group 10:
IOMMU Group 11:
IOMMU Group 12:
IOMMU Group 13:
IOMMU Group 14:
IOMMU Group 15:
IOMMU Group 16:
08:00.0 PCI bridge [0604]: Pericom Semiconductor Device [12d8:8608]
09:01.0 PCI bridge [0604]: Pericom Semiconductor Device [12d8:8608]
09:05.0 PCI bridge [0604]: Pericom Semiconductor Device [12d8:8608]
09:07.0 PCI bridge [0604]: Pericom Semiconductor Device [12d8:8608]
09:09.0 PCI bridge [0604]: Pericom Semiconductor Device [12d8:8608]
0a:00.0 USB controller [0c03]: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller [1912:0015] (rev 02)
0b:00.0 USB controller [0c03]: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller [1912:0015] (rev 02)
0c:00.0 USB controller [0c03]: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller [1912:0015] (rev 02)
0d:00.0 USB controller [0c03]: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller [1912:0015] (rev 02)
0e:00.0 USB controller [0c03]: ASMedia Technology Inc. ASM2142 USB 3.1 Host Controller [1b21:2142]
IOMMU Group 17:
IOMMU Group 18:
IOMMU Group 19:
IOMMU Group 2:
IOMMU Group 20:
IOMMU Group 21:
IOMMU Group 22:
IOMMU Group 23:
IOMMU Group 24:
IOMMU Group 25:
IOMMU Group 26:
IOMMU Group 27:
IOMMU Group 28:
IOMMU Group 29:
IOMMU Group 3:
IOMMU Group 30:
IOMMU Group 31:
IOMMU Group 32:
IOMMU Group 33:
IOMMU Group 34:
IOMMU Group 35:
IOMMU Group 36:
IOMMU Group 37:
IOMMU Group 38:
IOMMU Group 39:
IOMMU Group 4:
IOMMU Group 40:
IOMMU Group 41:
IOMMU Group 42:
IOMMU Group 5:
IOMMU Group 6:
IOMMU Group 7:
IOMMU Group 8:
IOMMU Group 9:
Note 2) I obtained a good IOMMU grouping the my Intel I350 network controller and for my graphic card but not for the StarTech USB Card!
Note 3) I didn’t experienced the issues identified at this URL for the StarTech card with 4.x [kernel: bugzilla bug id=199627]
  1. Some considerations
Having said that,
I hope Asus realize the USB Passthrough capabilities are an important feature a modern mainboard should support today!
Moreover I think Asus should spend even few official words on this topic at least to explain why we can’t get a good IOMMU Grouping for the USB card while in the case of graphic cards and network cards is possible to obtain a good IOMMU grouping!
Is the bad IOMMU grouping for USB cards related to the X470 chipset? Is it related to AMD AGESA?
Moreover I hope the “high end” USB card vendors take into account more seriously the information coming from users with their reports and tests and solve both basic compatibilities issues and the IOMMU grouping issues.
I hope my experience could be useful for people attend this forum and I hope they can share their experience too on this topic.
For instance, Is there some one can share their IOMMU Grouping of a PCIE USB card installed in an Asus CH7 and CH8 mainboard?
Many thanks and regards to all of you,
Cpt-Harlock
Hi,
I use without special problems:
(IOMMU group and passthrough ok)
Inateck [5 doors + 20pin] PCI USB card 3.0 5 USB ports 3.0 20-pin connector with 15-pin SATA connector, a 4 pin 2 x 15pin cable, a Y-Câble SATA socket (Fresco Logic FL1100 USB 3.0 Host Controller).
Or (IOMMU group ok, but I’m not using it currently with vm ):
SupaGeek PCI-E type C (1), type A (4) USB 3.0 5-Port PCI Express Expansion Card, capable of expansion + 2 USB 3.0 ports with pin interior Connector (RENESAS TECNOLOGY UPD720201 USB 3.0 Host Controller)
Linux Mint 20.2
KVM Virt-Manager Linux, Win, Macos VM
Purchased on Amazon
Hi Darius,
thanks a lot for sharing your experience! Those are important information.
I have a couple of question: What mainboard are you exactly using? Which BIOS version is present on your mainboard?
Thanks so much,
Cpt-Harlock
AsRock X99 WS
XEON E5-2697 V3
BIOS X99WS3.30, but modified to have the turboclock unlocked on all cores.
I think the important thing is the chip of the USB controller for compatibility with Linux and the IOMMU:
Fresco Logic FL1100 or Renesas Tecnology Upd720201 in my case
Hmm, I’ve had reset issues with the FL1009 in my Gigabyte board so it may be a firmware update issue.
VIA just refuses to work with IOMMU enabled.
I wonder if there is any correlation with the cards that work on the PI CM4 boards, like Jeff was testing?
like, maybe some add in cards are just better, but the mobo does play a big part.
I’ve not needed to pass a physical card through though, I just pass a whole controller from the motherboard, when I need that (like programming tom tom etc)
Hi,
I reply to myself just to add some information. I found a very useful document written by Levono engineering:
An Introduction to IOMMU Infrastructure in the Linux Kernel
This document is helping me to clarify my ideas on the IOMMU topic.
I noticed an interesting information. At the end of page 16, there is a sentence that says “When initializing IOMMU, Linux kernel creates 120 IOMMU groups (0-119)”
I then reread the document and I verified that the system they used in the test is indicated on page 14 in Table 2 “Lenovo ThinkSystem™ SR665 with AMD EPYC 7002 “Rome” family of processors”
So we know that the Linux kernel on an EPYC instantiates as many as 120 IOMMU groups!
I then ran the command on my system, remember that it is a 3900X and X470 chipset and I got: /////
sudo dmesg | grep “iommu group” | tail -n 5
[ 1.677750] pci 0000:10:11.6: Adding to iommu group 38
[ 1.849596] pci 0000:10:10.3: Adding to iommu group 39
[ 1.852601] pci 0000:10:10.7: Adding to iommu group 40
[ 1.861813] pci 0000:10:11.3: Adding to iommu group 41
[ 1.894204] pci 0000:10:11.7: Adding to iommu group 42
Now I would be curious to know how many IOMMU groups are instantiated of the Linux kernel on a mainboard with X570 chipset with 3900X processor or more’ modern.
I would like to understand if the number is always 42 or there are cases in which a greater number of IOMMU are instantiated.
Is there anyone who can help me verify this data?
I think that would be useful for many of us.
Many Thanks in advance!
Greetings to all, Harlock
I believe your Sonnet Cards would have worked fine but require ACS Override to be enabled to get separate IOMMU groups that you can than passthrough.
Have you tried / or are using the enable Above 4G Decoding in BIOS?
Hi Carbongrip,
thanks for your suggestion!
I had also thought about the possibility of using the ACS patch, however both as indicated by Sonnett following my interaction with their technical support (Linux Compatibility note) and for some “limits” introduced by the ACS patch, I decided to try to use the 'IOMMU grouping provided by the motherboard.
Yes, I’m using the “Above 4G Decoding”.
Greetings,
Harlok
Good morning everyone,
these days I performed other tests and I read other articles on VFIO, IOMMU and so on.
I would therefore like to share what I have found with the hope that it will also be of help to other people.
Below is a brief indication about the position of the PCIe cards on my Asus Crosshair VII Hero motherboard in two different scenarios and the relative distribution of the IOMMU groups.
Scaenario A - See also figure Fig. 1
In the PCIEX16/8_1 slot I installed the EVGA 1050Ti Video Card.
In the PCIEX8/X4_2 slot I installed the Intel I350 NIC.
In the slot PCIEX4_3 I installed the StarTech PEXUSB3S44V card.
Fig 1
The system allocates the IOMMU groups as follows:
IOMMU Group 0:
IOMMU Group 1:
IOMMU Group 10:
IOMMU Group 11:
IOMMU Group 12:
IOMMU Group 13:
IOMMU Group 14:
IOMMU Group 15:
IOMMU Group 16:
IOMMU Group 17:
IOMMU Group 18:
IOMMU Group 19:
IOMMU Group 2:
IOMMU Group 20:
IOMMU Group 21:
IOMMU Group 22:
IOMMU Group 23:
IOMMU Group 24:
IOMMU Group 25:
IOMMU Group 26:
IOMMU Group 27:
IOMMU Group 28:
IOMMU Group 29:
IOMMU Group 3:
IOMMU Group 30:
IOMMU Group 31:
IOMMU Group 32:
IOMMU Group 33:
IOMMU Group 34:
IOMMU Group 35:
IOMMU Group 36:
IOMMU Group 37:
IOMMU Group 38:
IOMMU Group 39:
IOMMU Group 4:
IOMMU Group 40:
IOMMU Group 41:
IOMMU Group 42:
IOMMU Group 5:
IOMMU Group 6:
IOMMU Group 7:
IOMMU Group 8:
IOMMU Group 9:
Scaenario B - See also figure Fig. 2
In the PCIEX8/X4_2 slot I installed the StarTech PEXUSB3S44V card.
In the slot PCIEX4_3 I installed the Intel I350 NIC.
Fig 2
IOMMU Group 0:
IOMMU Group 1:
IOMMU Group 10:
IOMMU Group 11:
IOMMU Group 12:
IOMMU Group 13:
IOMMU Group 14:
IOMMU Group 15:
IOMMU Group 16:
08:00.0 Ethernet controller [0200]: Intel Corporation I350 Gigabit Network Connection [8086:1521] (rev 01)
08:00.1 Ethernet controller [0200]: Intel Corporation I350 Gigabit Network Connection [8086:1521] (rev 01)
08:00.2 Ethernet controller [0200]: Intel Corporation I350 Gigabit Network Connection [8086:1521] (rev 01)
08:00.3 Ethernet controller [0200]: Intel Corporation I350 Gigabit Network Connection [8086:1521] (rev 01)
09:10.0 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
09:10.1 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
09:10.2 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
09:10.3 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
09:10.4 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
09:10.5 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
09:10.6 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
09:10.7 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
09:11.0 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
09:11.1 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
09:11.2 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
09:11.3 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
09:11.4 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
09:11.5 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
09:11.6 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
09:11.7 Ethernet controller [0200]: Intel Corporation I350 Ethernet Controller Virtual Function [8086:1520] (rev 01)
IOMMU Group 17:
0b:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP107 [GeForce GTX 1050 Ti] [10de:1c82] (rev a1)
0b:00.1 Audio device [0403]: NVIDIA Corporation GP107GL High Definition Audio Controller [10de:0fb9] (rev a1)
IOMMU Group 18:
0c:00.0 PCI bridge [0604]: Pericom Semiconductor Device [12d8:8608]
IOMMU Group 19:
0d:01.0 PCI bridge [0604]: Pericom Semiconductor Device [12d8:8608]
IOMMU Group 2:
IOMMU Group 20:
0d:05.0 PCI bridge [0604]: Pericom Semiconductor Device [12d8:8608]
IOMMU Group 21:
0d:07.0 PCI bridge [0604]: Pericom Semiconductor Device [12d8:8608]
IOMMU Group 22:
0d:09.0 PCI bridge [0604]: Pericom Semiconductor Device [12d8:8608]
IOMMU Group 23:
0e:00.0 USB controller [0c03]: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller [1912:0015] (rev 02)
IOMMU Group 24:
0f:00.0 USB controller [0c03]: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller [1912:0015] (rev 02)
IOMMU Group 25:
10:00.0 USB controller [0c03]: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller [1912:0015] (rev 02)
IOMMU Group 26:
11:00.0 USB controller [0c03]: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller [1912:0015] (rev 02)
IOMMU Group 27:
IOMMU Group 28:
IOMMU Group 29:
IOMMU Group 3:
IOMMU Group 30:
IOMMU Group 31:
IOMMU Group 4:
IOMMU Group 5:
IOMMU Group 6:
IOMMU Group 7:
IOMMU Group 8:
IOMMU Group 9:
  • You may notice that there is a link between the PCIE slot in which the Intel I350 or StarTech PXE PEXUSB3S44V cards are installed and the association of the IOMMU groups.
  • It is also possible to note that the number of IOMMU groups instantiated in scenario A and B is different. I have not yet tried to passthrough one of the USB controllers on the StarTech card in Scenario B to a VM, as soon as I have performed this test I will make the results known.
In any case this is a result: now we know that on an Asus C7H motherboard, therefore with X470 chipset, in order to passthrough a USB controller on a PCIe card, a fundamental requirement is that the card is installed or in the slot “PCIEX16 / 8_1” or in the “PCIEX8 / X4_2” slot.
At this point it would be useful to know the behavior of an Asus C8H motherboard, therefore with X570 chipset, with two similar PCIe cards positioned in the PCIEX16_2 slot and PCIEX16_3 slot (See Scenario A) to check if the X570 chipset has the same limitations as the X470 chipset in associating IOMMU groups to PCIe slots.
Therefore I ask all users the following question: is there any of you who has an Asus C8H motherboard, so with X570 chipset and two PCIe cards “similar” to check the (Senario A) configuration?
Greetings to all and thanks for your cooperation,
Cpt-Harlock!!
I’m not to surprised with your findings. Prior to the x570 chipset all AMD chipsets did not separate devices installed in ports serviced by the chipset. And that 3rd slot in the board is a chipset based slot.
The first m.2 slot is cpu served as well, so sometimes you can make a compromise and use that slot with a pcie adapter.
I’ve had mixed luck passing through cards attached to the chipset with the ACS overrride enabled, but for more basic devices it seemed fine.
There are 39 groups in my setup that’s based on an X570 board using a Ryzen 5950x.
After a bit of experimentation I settled on Inateck’s KT4001 USB controller (seems like darius above uses KT5001) - it resets fine and falls in its own group:
IOMMU Group 29:
        25:00.0 USB controller [0c03]: Fresco Logic FL1100 USB 3.0 Host Controller [1b73:1100] (rev 10)
This was after using the following cards:
  • Allegro Pro USB 3.1 PCIe Card
  • StarTech PEXUSB3S44V (which you seem to have tried, too)
It’s been a while so I don’t exactly remember what my issue was with each, but I think devices weren’t connecting on one of them (and IOMMU groupings was probably another issue).
Anyway, I’m looking at multiple controller cards again since my motherboard apparently shares a USB controller for IPMI input devices and motherboard USB devices. There are three on my radar at the moment, maybe they’re of interest to you:
SIIG JU-P40811-S1
XT-XINTE USB Card
IOI U3X4-PCIE4XE111
The first two seem to use Renesas’ uPD720202 and the last one uses Fresco Logic FL1100, which seems promising. I found the XT-XINTE one via this youtube video, which seems to illustrate that it properly allocates separate groups:
Hi Grendel,
sorry for this huge delay in my answer…
Many thanks for your replay.
I didn’t know there was a PCIE slot served by chipset. For me this is a very useful information to know. Do you have any pointer to documents and/or articles to read more in detail?
it would be very useful to be able to run a practical test and try a motherboard with X570 chipset and insert a multiport USB card in one of the “last” PCIE slots to verify that the IOMMU separation is effective …
The idea to use the M2 slot is interesting!
Greetings,
Harlok
