I am using qemu directly, my launch args are very specific and tuned to my hardware configuration. It’s very unlikley to be of any use to you.
I stopped running this setup after I found that USB passthrough of my sound card (Focusrite 2i4) had too much overhead. I ran MacOS fine with the 6600 but I can not remember which version it was.
Hi all, just discovered this thread. Is there a newer thread on splitting GPUs in vGPUs? Especially nVIdia and non datacentre ones? I’ve been using full GPU passthrough for years with Proxmox, works great but for some cases I need to split some GPUs to multiple VMs.
Thanks!
yeah, search for the flex 170 / a770 thread.
