Very Quick Question
Will a GIGABYTE GA-MA790X-UD4P AM3/AM2+/AM2 AMD 790X ATX AMD Motherboard ---- http://www.newegg.com/Product/Product.aspx?Item=N82E16813128387
Go good with a Antec Three Hundred Black Steel ------ http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
And a AMD Phenom II X4 940 Deneb 3.0GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM2+ 125W Quad-Core Black Edition Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103471
yes
+1
+1
+2 Yeah son
YEA BOI!!!!!!
Get an X4 955 BE as a CPU.
+1 more
+1 He's Right get the QUAD 955 for a better overclock at a lower voltage, DO IT!!
All right I checked on newegg and it is only 25 bucks more. Ya I might get it. Thanks guys. =D
hey, if ur getting the 955 be with a gigabyte MB your gona have to flash the bios, and there "in windows" bios flasher tool sucks balls... so your going to have to use q-flash in the boot menu. but not that big of a deal....
if you dont flah your core speeds will be 1.62 ghz (core 0,1,2,3) or 1.62(core 0), 800mhz (core 1,2,3).
