Very First Gaming Pc
Hi guys,
I'm building my first gaming rig and i need need some help for the components that I am missing. I already have a PSU, RAM, SSD and the computer case.
The components i have are:
- PSU: CoolerMaster Silent Pro Gold 550W
- RAM: PATRIOT Master Viper 3 Series 2 x 4GB DDR3-1866
- SSD: OCZ Vector Series 128 GB
- Case: Fractal Design Core 3000 USB 3.0 Black
Meaningful information:
- Budget. Around 800€
- Where do you live,  and what currency do you use? Portugal and therefore, Euro.
- Is there a retailer you prefer? Not really.
- Do you need or already have peripherals? Yes, i need a monitor.
- What will you be using your future computer for? This Pc will be for gaming and some light programming.
- Do you overclock or want to get into overclocking? I don't but i would like to learn how to.
- Do you plan on going for custom watercooling now, or in the future? Now since it is needed for Overclocking.
- OS. Do you need a new one? Would like to but if you can use that money to get a better GPU(example) i can go pirate for now.
- Do you plan on Mining BTC either for yourself or Tek Syndicate? Don't quite understand what this means.
- What kind of settings do you like or what FPS do you want to play at? I'd like Ultrasettings with playable frame rates.
- What resolution will you be playing at? Depends on the monitor but sould be 1080p.
- What kind of games do you like to play? I've grown tired of LoL since it's kinda the only game i can play in my Macbook Pro 13". I want to experience all the games out there like Crysis, Battlefield, Metro, Bioshock, etc.
- What specific game will you be playing? Written above.
- What size monitor are you looking for, and what resolution? Screen type (IPS, S-IPS, TN, etc.), hertz (60, 120, etc.) About this i do not understand a bit so i'm open to what you guys suggest.
These parts were given to me so i wasn't quite able to pick them. I think they can be returned if it needed. From what (I think I) know I need CPU, Motherboard, GPU, Monitor, HDD and a water cooler.
I found this forum through the youtube channel and i watched some videos but i'm still confused about "fx-8350 vs i5 3570k" and those kind of things cause there are very distinct opinions on that.
Thank you in advance and, as usual, sorry for my lack knowledge on the English language as it is not my native one.
P.S.: Don't be afraid to throw in some tips about parts, specifications to watch for, formatting,  English language, life hacks, everything. I'm here to learn :)
http://es.pcpartpicker.com/p/1JNSs
This build will easily max out most games at 1080p. Since I have no real way of knowing the price and availability of parts in Portugal, (pcpartpicker does not support Portuguese retailers and creating a build by using Portuguese sites alone would take me all day since I don't speak the language) I left a great deal of room in the budget. If this build comes in dramatically under budget, let me know how much room you have, and I'll recommend you adjustments to the build.
hello there!
I´m not sure what portuguese sites there are that sell computer parts (I´ve found pcdiga.com, however they don`t have many products...)
since you said you are going to be gaming mostly, i would suggest an AMD FX-8 series Processor, the 8320 and 8350 offer lots of performance for great prices (~150-200€)
You can overclock these Processors quite easily...
If you would like to try overclocking, but don`t think that it`s necessary to you, you won`t be needing any watercooling...
I have got the FX-8320 running between 3,5 and 4Ghz with an ordniary air cooler, it`s a Xigmatek Loki and it runs very cool and pretty quiet...
for a GPU, I would recommend the AMD Radeon HD-7950, I´ve bought one recently for 200€ (in Germany) and it runs like hell (good&fast enough for every modern game on the best settings at a resoultion of 1920*1080)
there are however different Options from AMD and Nvidia,but I think AMD beats Nvidia at price-performance, thats why I prefer them...
 But you could also wait for the next generation of AMD Graphics cards, which will of course be even faster then the current ones...but as a sideeffect, when the new cards are released the last generation will get cheaper...
The GPU market is pretty complicated, to be honest with you...
 for your Motherboard, you can get about any AM3+ socket Mainboard for 80-150€ for a good, basic one that will support USB3.0, SATA3.0 and such stuff...I´d recommend to get one from Asus, MSI oder EVGA since those are the most reliable producers...
the components that you have should be good for such a build...
you should install the OS on the SSD, for your Games, Music, Videos and Pictures you should get a HDD with 1 or 2TB...for example from the Western Digital Caviar Green Series...
 for a Monitor, you can get anything for 100-200€, make sure it does 1920*1080p, has a reaction time of 5ms or less...IPS or LED are better than LCD...
It is great that you are interested and willing to learn about Computers! i suggest that you continue to watch the Build videos of the Tek Syndicate, you`ll always learn something...also there are many videos on their channel benchmarking different CPUs and GPUs that are worth a look...
I hope this helps you deciding what parts to pick for your build...
regards, Julian
Using your build and taking away the parts that i already have the cost is around 500€.
So you can still upgrade that build in 150€, assuming the monitor costs around 150€.
Thank you for your reply.
http://es.pcpartpicker.com/p/1JOnl
Unfortunately, you did not quite have enough room left in your budget to add a second GPU for crossfire. Instead, I added a better CPU cooler, CPU, motherboard, and power supply, this will get you better performance in some CPU intensive games, and allow you to add another 7950 in the future.
Thank you very much Julian. Glad you took the time to help me.
I was thinking of getting the following parts AMD FX-8350, Asus Sabertooth 990FX R2.0.
When it comes to the GPU it gets a little harder cause i might wait to see what the new AMD Radeon RX 200 Series have to offer. So basically either one of the incoming AMD GPUs or one of the versions of the 7970 (which i will have to search and study carefully) which, as you said, will get cheaper.
What do you think?
Since I already have the Case and the RAM don't you think i can upgrade that FX-6350 to a FX-8350?
If you can fit an 8350 in your budget by just knocking off the RAM, sure. I would strongly recommend getting a new case, though, the airflow in the core 3000 is pretty bad.
Edit: I was thinking of the core 1000, the core 3000 is alright, however you will have to use the UF12s instead of the UF14s heatsink.
Thank you. You scared me there for a sec though xD
About the heatsink, i can't seem to find the model you are refering to.
I think he did a typo.
Noctua NH-U12S
And is 550W enough for that system? And what card do you recommend for the Radeon HD 7970?
550w is Plenty.
I like sapphire cards:
http://pcpartpicker.com/part/sapphire-video-card-100351sr
Everything is so much more inexpensive in the USA. That card costs around 100€ more here. Do you know any stores that may ship to Portugal?
FX-8350 and that Motherboard would surely work, you should take a look at Asus Support page to see if your memory has been tested with that motherboard...
If you could wait another month with your build, there will be more details on the new graphics cards from AMD, regarding pricing and the processors used in them (there are rumors that most of the new R9 series will be rebranded 7xxx series...Tahiti XT or Tahiti LE...)
also, the prices might drop more for the 7xxx Series...
I would recommend buying the graphics card in Portugal since you will have difficulties with warranty if you order one from america...also, the shipping cost if you order from america will be quite high...you could check if there are shops in france, spain or germany that have lower prices who ship to portugal...
in germany, you could check at alternate.de , caseking.de, mindfactory.de, cyberport.de...
also, it doesn´t really matter what brand you get, asus, msi, evga, xfx, gigabyte, powercolor, his, vtx3d and almost everything else is fine...
I´ve compared several prices, including shipping to Portugal for AMD 7970 graphics cards from several german, french and spanish online shops, the cheapest option would be to order it from Germany, the total cost would be approximately 285€...
http://www.caseking.de/shop/catalog/Grafikkarten/Alle-Grafikkarten/ASUS-Radeon-HD-7970-DC2T-3072-MB-DDR5-PCIe-30-DP-HDMI::22921.html?campaign=psm/idealo-de
however those prices will fall even more, once the new Radeon R7 and R9 series are on the market...you could get them then for a total of  260-270€, but that is only a very rough estimation...
Well. I found that NCIX shipps to Portugal and it is 100€ cheaper.... No joke... CPU, GPU and motherboard
Keep in mind you will most likely be paying additional tax for any goods being shipped from outside EU.
i know for now you think that your psu if enough at 550w but i recommend getting the biggest one you can, personally i bought a 500w and im having to upgrade that increasing my budget from what i wanted it to be, if you have the chance to get a big one new, then do it
