Versus! Help me choose and give pros and cons please thanks guys!
Okay Ive posted on here about building pcs before. I now have to options, a 700 and 1000 pc.
http://pcpartpicker.com/p/R4xVP6 ------ $700
http://pcpartpicker.com/p/9jBjQ7-------$1000
I can do the 1000 pc, but i would rather do the cheaper option. im not that picking on framerate, but i still want it to be decent(30+) 1080p. Would i be happy with the $700 option or should i just go in with the $1000
Also i am getting a mouse, keyboard, OS, and 2 monitors($160 per monitors). Keep that in mind!
Thanks for the help!!
Go with the 1k build. It will last you much longer. If you don't plan on OCing, swap out the K with a non-k and you are good to go. Or just keep it since the price difference isn't that large.
You really won't be running at 30 FPS, you will be at 60+ on the rig, and will be for a while.
