Hi,
running a small home network with various VLans:
- Edge Router Lite
- 1 x Zyxel Switch
- Raspberry pi for DNS
Using the firewall on the router, I was able to segregate the different networks and it “seems” to work; but I want to be sure. Are there any software tools out there that allows me to probe the network in a systematic way. Naive picture: Laptop with 2 NICs, plugin into two different ports on the switch and run various tests against the neworks; e.g. does it route, can it reach other endpoint, DNS available … etc.
Does something like this exist, or how is it done in the enterprise?
– Thx
