I have this problem with my PC. In short, after a while, when the PC is idle, it stops outputting video and the system freezes. Doesn’t respond to input or monitor restarting or plugging or unplugging the video card.
I’m not exactly sure if it’s a GPU problem, but after I manually restart the system, I get a little pop-up saying: "Defaul Radeon WattMan settings have been restored due to an unexpected system failure.
My card (Sapphire Nitro+ Vega 56) has that feature that it keeps the fans off unless it reaches a certain threshold temperature. (I’m not sure if this is a Vega 56 property or this card in particular)
I thought that perhaps the card was heating up too much too quickly and the fans weren’t responding so it was shutting off, so I changed the default fan profile to always on in WattMan. However, this doesn’t seem to help.
Listed below are my system specifications.
Asus X570 Strix-E with the newest bios installed (1.0.0.4). Chipset drivers are also up to date.
Ryzen 3900X, stock cooler, stock settings. PBO off. I tried the regular power plan, the AMD Ryzen Power plan and the 1usmus Custom Power Plan 1usmus Custom Power Plan. It happens on all of them.
4x8GB sticks of 3200MHz CL16, running at rated XMP settings.
1x Samsung SSD 256GB with Win10 on it, 1x Crucial 240GB SSD from, and 1x WD HDD
EVGA 850BQ 80+ bronze PSU. The PCIe power cable is NOT daisy chain connected. I have two directly from the PSU to the GPU.
HP Omen 32. Connected by a display port cable.
Win10 with the latest update and Radeon drivers are also fully updated.
I’ve turned off sleep and hibernate both on windows and the monitor itself.
This has been happening for a while - persists through different windows and driver updates. Furthermore, my games run perfectly well - Deus Ex Mankind Divided, and Star Citizen among others, somewhat less demanding.
The problem seems to occur only when the PC is idle. Any help would be greatly appreciated.
