VBox Resolution
Anyone know how to get 3840x2610 resolution in a VM?
Ubuntu host & guest
in oracle virtualbox?
if so:
VBoxManage setextradata "<vm-name>" "CustomVideoMode1" "3840x2610x32"
and start the vm. There’s also
VBoxManage controlvm "YOURVMGUESTNAME" setvideomodehint 3840 2610 32
while the vm is running, might not persist, don’t remeber the details.
but, if that’s a native resolution of the monitor, after installing the guest tools it should have worked automatically
Cheque
where am i putting those settings? and what does the 32 represent?
in the terminal, VBoxManage is a utility installed when you install virtualbox
color depth.
