It’s cool. I think it’s fairly generally acknowledged that most of the people who hang out here can’t really be included when talking about reactions of the general public to technology.
I came so close to having that block and that card… somehow I killed it or was killed in transit… note to self… test exspensive hardware before modification… hope it works out for ya!
Ok filling to check on hardware labs huge 8 port. 240mm radiator. Wish me luck got physical plugs. Epoxy welded into a push filled(with same 2 part epoxy). Do not think I left enough exposed to flow to gum up any block. But waiting on amp draw for leds anyway might as well check!
Engrish needs practice you determine what I’m up to.
Sans everything but weird sunglasses at night and trucker hat! I split a velociraptor 15k open. And yes you are welcome for the sans everything mental image. My house my rules…
Can confirm 3M double sided tape has held my Go-Pros attached to my motorcycle/helmet up to/beyond 240km/h, over several years exposed to the elements. I’m not sure what specific spec go-pro supply on their mounts, but it’s definitely 3m branded.
If it can do that i’d suggest its plenty for PC building use
