I am on a tight budget so,
Should i get i7 4770k or i7 4790 non "k".
This build would be used for music production that is cpu intensive task and sone games.
I have amd R9 toxic 270x for video.
Maximus vi hero board.
And another thing,
Currently I'm getting 22" monitor and wd black 1tb.
But i also like some more workspace on 24" inch hd panel and wd blue 500gb.
I would like to know your opinions for what would you do if you were in my kinda situation.
What do you have already?
And do you already have that motherboard? The only reason to get a "K" part is if you are wanting to overclock. So if you don't want to overclock then you can save the money and get the regular 4790.
A i7 4790 is pretty much a pre overclocked i7 4770k depends if you whant to overclock or not (the none k has a locked multiplier so no overclocking)
Why not get an i5? Plenty of power for your needs. Equal to the i7 in gaming.
+1
Tight budget? Gaming? no reason to get an i&, nab up a 4690, with a cheap non-OC motherboard (h-97), and enjoy power without spending a ton of money.
http://pcpartpicker.com/p/xPtbwP
^- i5-4690 and cheapest H97 mobo with m.2 support
http://pcpartpicker.com/p/tvC223
^- Xeon E3-1230 V3 / same mobo...
I don't think music production would warrant 8 threads... but if you want cheap hyperthreading, there it is...
