Usr/sbin/cups-browsed process
does anyone know what the process usr/sbin/cups-browsed is, it was receiving about 1mb per second and then it would stop for about 10 secs and start downloadibng again. the process only shows up using Nethogs from the terminal, the only way it would stop downloading was by deleting the process from usr/sbin
it’s the network daemon component of the Common Unix Printing subsystem
scanning for networked printers, most likely
