Hey guys, I want to get into video editing and I have got an nvidia 650ti that I normally use for stuff like video editing. Does anyone know of any software that I can use to render videos with my nvidia 650ti and that way I don't have to render the videos with the CPU in the computer, because that can be a bit slow sometimes. Thanks! This is my first time posting, so I don't know if I am doing everything right. Thanks again.
-Chris
You can use the cuda cores on the gpu for that (and maybe opencl, not sure) if you use premiere pro. Your card does not seem to be supported out of the box though. Read further here: https://forums.adobe.com/message/4552694.
Yeah, I was watching the inbox.exe and Logan in the thing where he was showing him how to set that up. Thanks.
I use the 650Ti also for video editing and it does speed up renders a bit. But you will need to do the Cuda hack for Adobe Premier Pro CC.
You mean like the one that Logan did for that inbox.exe thing (accept I would just add it to my CUDA files)
Well at GTX 650 Ti to cuda txt files and download the cuda drivers.
