Hi there, not sure if this is the right category or not but not sure 100% where to put this. I have 2 Supermicro 847 chassis. One is my current NAS and the second I’d like to essentially pass through the drives to the main NAS while also having a second remote gaming PC (AMD B550) in it. I have the external SAS connectors, but not sure how to handle power. I’d like to be able to reboot the secondary PC without cutting power to the drives if possible.
If anyone has any ideas I’d love to hear them. For now I’ll put it together and just not use the drives until I need to, or just set the PC to run forever and auto start if it loses power, but I’d love a better solution if people have it.
Just curious, but would that allow me to use 1 PSU for both? Currently the chassis has 1 24 pin and the drive back-planes are molex. I was hoping to use the existing PSU setup as those PSUs are really solid.
Maybe clarifying my setup is in order:
1 Supermicro 847 with my main server
1 Supermicro 847 with a secondary PC that I want to turn on and off/sleep independent of the drive bays which are on molex connectors and system only has 1 PSU.
Can your NAS 847 power supply theoretically supply enough power for the second bank of drives? If so, you could try and come up with some kind of custom extension to run power up to the second chassis’ drive backplane. Then the other power supply would just be powering the gaming PC build in the back of that second 847 chassis.
Otherwise you’ll need to just remember to never power off the gaming PC so that you’re sure that the drives in that case remain powered for your NAS.
Otherwise maybe some kind of small extra psu for the drive plane in the second chassis and set up a jumper cable between cases to slave that PSU to the main one below?
Maybe if you have redundant PSUs in the Supermicro chassis, you might be able to split them up somehow? Not really sure that’s feasible without a lot of custom work.
Those have the dual power supplies in them? I would disconnect the PSU merger and run 1 PSU to power the drives and the other to power the PC.
You could probably simply disconnect one of the PSUs from the merger, and it might still function fine. That way you dont actually have to router wires back to the backplanes and can just keep everything connected as is but just pull the wires from 1 of the PSUs over.
