So I have my personal laptop here at work and it will not connect using an Ethernet cable. Of course, we are not supposed to use outside laptops but my current work one is a piece of junk. Is their a program or something where I can use my company's hard internet connection? It will not connect as is.
Thanks guys
Don't risk them blaming you for anything that goes wrong with their shitty system man.Your home laptop should just stay off their network.
Go to you manager an explain that you feel the supplied laptops are not sufficient for the tasks which you are expected to carry out on them. If they say no then it's on them because they aren't giving their employees the right tools for the job.
Nothing you can do if that's the mindset, except just be as productive as conditions allow and go home without a second thought about it.
Thanks man, that's what I'm going to do. It's a POS.... still running XP!!!!!!!!!
