I have just found out that the thermostats and home security system are all "Z-wave enabled" honeywell units.
My question is if there is a way to use an inexpensive arm dev board to serve as a replacement to a "z-wave controller" for these units.
The units specifically are the Honeywell TH8320ZW1007/U thermostat (total of 2) and the Honeywell L5100 LYNX home alarm panel (total of 3). Both would need the z-wave controller upgrade units to be able to speak to the z-wave controller naively.
I would like to be able to control the thermostat's schedule remotely via a web interface as well as arm and disarm the house, preferably with email or text alerts when the home security system is disarmed.
