When I am plugged into my kvm PulseAudio keeps dying over and over again (I have tried with pipewire as well and get the same behavior). I believe I found it is linked to problems with the kernel communicating with the sound card on the kvm? Here are a couple logging commands and their outputs below.
$ journalctl -e
Jan 21 11:18:21 worktop kernel: usb 1-4.1.1: 1:1: cannot set freq 48000 to ep 0x1
Jan 21 11:18:26 worktop kernel: usb 1-4.1.1: 1:1: cannot set freq 48000 to ep 0x1
Jan 21 11:18:31 worktop kernel: usb 1-4.1.1: 1:1: cannot set freq 48000 to ep 0x1
Jan 21 11:18:36 worktop kernel: usb 1-4.1.1: 1:1: cannot set freq 48000 to ep 0x1
Jan 21 11:18:41 worktop kernel: usb 1-4.1.1: 1:1: cannot set freq 48000 to ep 0x1
and I believe the usb 1-4.1.1 refers to the sound card of the kvm
$ lsusb -t
/: Bus 001.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/12p, 480M
|__ Port 004: Dev 016, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 001: Dev 017, If 0, Class=Hub, Driver=hub/7p, 12M
|__ Port 001: Dev 019, If 0, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 001: Dev 019, If 1, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 001: Dev 019, If 2, Class=Audio, Driver=snd-usb-audio, 12M
Right I was meaning in the blue USB 3.0 ports some people have had luck plugging a powered USB hub into it and running their problem child usb device through it
Surprisingly enough the above error doesn’t have anything to do with another usb device connected to the KVM, this problem comes from the KVM itself. The usb 1-4.1.1 I believe is actually just the internal sound card of the KVM.
Any further thoughts on this? strange thing is it was working for a couple weeks before this behavior too. If not, could I maybe exchange it for one of the HDMI models?
Re-set up the kvm and am no longer having the issue! Maybe fixed by kernel updates or something. I did also switch to pipewire which may have helped (if anyone in the future has similar problems)
Had this problem occur on the second KVM I bought as well and found that unplugging and replugging in my webcam might have fixed things. Not sure if I didn’t do that the first time, but that seems to help if anyone else has a similar problem.
