Looking for a usb wireless adapter that will work easily with fedora. I don't want it to cost a lot or support ac; just using it to get on the internet nothing special.
You could look into what works for a Raspberry Pi, then you'll be quite secure in knowing the driver modules is probably also in fedora.
I would suggest this one
It's cheap and you can basically plug and play with anything. I have never personally tested it on fedora but I have it running on my pi right now and it seems to work great.
