What do you think would be best to carry an internet connection from the router downstairs to my new PC upstairs into my bedroom. i get speeds of about 50 mbps down, downstairs and would like to get something similar up in my room. so which would be a better option, USB adapter or a PCI one?
I'm assuming you mean wifi. I would grab a PCIe card. You more than likely have a PCIe 1X slot that you aren't using. A card will usually give better performance and won't take up a USB port.
