Hi! I’m trying to use my 3D mouse with my cloud-based workstation, but I’m hitting a wall because the cloud environment doesn’t let me use the 3D mouse. So, I have a question: has anyone here managed to connect USB devices like this to a cloud environment?
What tools have worked for you?
I ran into the same issue when I moved my setup to a cloud workstation. Regular remote desktop solutions often don’t support USB devices like a 3D mouse, so I looked for something more specialized. I found a tool that works, and you can find more information here USB to Cloud passthrough with USB Network Gate
A good option is USB-over-IP software like USB Network Gate or FlexiHub. These tools basically let you share your local USB devices over the network, so your cloud workstation “sees” your 3D mouse as if it’s plugged in directly.
