USB-Switch / KVM and latency for competitive gaming?
Any idea whether these usb-switches would introduce latency to my mouse and keyboard?
UGREEN USB Switch 2PC KVM USB Switch 2 In 4 UGREEN USB Switch 2PC KVM USB Switch 2 In 4 Out für stabile Datenübertragung Umschalter mit 2 USB Kabel für Tastatur, Maus, Drucker, Scanner, USB Sticks, Externe Festplatte, Headsets usw. : Amazon.de: Computer & Zubehör
UGREEN USB Switch 2PC mit 1xUSB C Port und 3xUSB A Ports, 2 In 4 Out USB 3.0 Switcher UGREEN USB Switch 2PC mit 1xUSB C Port und 3xUSB A Ports, 2 In 4 Out USB 3.0 Switcher Alugehäuse mit Desktop-Kontroller, 2 USB A auf A Kabeln für Tastatur, Maus, Drucker, Scanner, USB Stick usw.: Amazon.de: Computer & Zubehör
I’m playing competitive shooters and would like to avoid latency at all costs but really would appreciate such a switch to run my Gaming PC and Mac with the same periphery.
I personally would prefer this one with USB inputs:
Although I don’t know whether their 3.2 usb switch without power input would be a better option?
I have heard in the past that PS/2 connectors are the way to go rather than USB for competitive gaming. USB has a polling rate while PS/2 does not (its a direct wire). Daisy chaining USB will likely degrade the latency even further.
Lol I need a serious answer.
@regulareel isn’t wrong. If you are that concerned then it’s a fair answer to your question. Otherwise the latency you will experience through a USB hub is negligible compared to what the network connection will introduce.
Is it a fair answer? The last time I saw a new board with a PS/2 port was 2011.
Problem I have I use a mouse with 1 ms latency so I probably should get then a second one for my second system and just use the hub for my dongles and non-latency relevant stuff?
@Melodist I dont mess around outside The Lounge. You are welcome
https://www.reddit.com/r/buildapc/comments/17m89e8/modern_motherboards_that_have_ps2_port/
X670 boards
ASUS X670E "ROG Crosshair X670E Gene"
ASUS X670 "Prime X670-P Wifi (-CSM)"
ASUS X670 "Prime X670-P(-CSM)"
B650 boards
ASUS B650 "TUF Gaming B650M-E Wifi"
ASUS B650 "TUF Gaming B650M-E"
ASUS B650 "PRIME B650M-A II Wifi (-CSM)"
ASUS B650 "PRIME B650M-A II (-CSM)"
ASUS B650 "PRIME B650M-A Wifi (-CSM)"
ASUS B650 "PRIME B650M-A (-CSM)"
ASUS B650 "PRIME B650M-A AX II"
ASUS B650 "PRIME B650M-A AX"
ASUS B650 "PRIME B650M-K(-CSM)"
ASUS B650 EX-B650M-V7
ASUS B650 "Pro B650M-CT-CSM"
Biostar B650E "B650EGTQ Racing"
Biostar B650 B650M-Silver
Biostar B650 B650MXC PRO
Biostar B650 B650MT-E PRO
Biostar B650 B650MP-E PRO
Gigabyte B650E "B650E Aorus Tachyon"
Gigabyte B650 "B650 Gaming X AX (rev 1.2-1.4)"
Gigabyte B650 "B650 Gaming X AX (rev 1.0/1.1)"
Gigabyte B650 "B650M Gaming X AX"
Gigabyte B650 "B650M DS3H"
Gigabyte B650 B650M C V2
Gigabyte B650 B650M K
Gigabyte B650 "B650M GAMING WIFI"
Gigabyte B650 B650M D3HP
Gigabyte B650 B650M D2H
MSI B650 PRO B650M-P
also from the same reddit post
ok fine i do mess around
Haha man it’s not what I wanted but I appreciate the effort :heart:
