Simple thing, I want basically Etcher but for android. I have a crap load of OTG’s to use and lose, so I figure if I’m going out on a system rescue call I’dxrather just plug a usb into my phone to write an emergency boot disk, rather than lug around a laptop.
I suppose it would be good for others should they not know… but I literally just searched myself. A cursory search would have yielded similar results for him. I dont feel like this is a thread that needed to exist. Especially under ‘community blog’. Take some time to do a little looking for yourself and maybe post your findings instead of asking the community to do the easy stuff for you.
Sometimes I don’t know how to search for things, like how to describe it. I wouldn’t think to just search BalenaEtcher for android, and I actually have and THAT didn’t pop up.
Anyways, enough of that, it seems you have found what you are looking for. I’ve marked Adubs’ post as the solution, feel free to uncheck it if you disagree.
