USB sometimes flaky connection, TRX50 issue?
About a month ago, I suddenly had my phone (Pixel 7a) disconnect and reconnect while plugged into USB. Has anyone seen this before?
Specifically, there are 2 behaviors:
Connect for ~2 seconds, then disconnect.
Connect, but occasionally (1min-1hr) disconnect for ~2 seconds.
I’ve mostly been getting the second one. The weird thing is that inserting a USB hub between my phone and mobo, or using certain ports, will stop this from happening. Additionally, a fresh reboot will also clear this for a period of time.
I’m running an ASRock TRX50 WS mobo. Has anyone else on TRX50 or Threadripper 7000 seen this? Ryzen? In general?
Linux kernel version doesn’t seem to matter. I can go into more detail if needed. I’ve done a lot of testing, and it’s not the cables, power draw, or the phone (probably, it doesn’t cause this issue on my Intel laptop at least). It looks most like a USB 2.0 vs USB3.x PHY issue of sorts, as it only happens on USB3 ports, despite the phone only connecting at USB2 speeds. But again, from January-May, I had no issues with this.
Sample dmesg:
[Thu Jul 11 22:14:06 2024] usb 2-2: USB disconnect, device number 56
[Thu Jul 11 22:14:08 2024] usb 2-2: new SuperSpeed Plus Gen 2x1 USB device number 57 using xhci_hcd
Recently happened to plug my phone into USB-C on my 5950X build and got the connect for ~2s, disconnect, connect, disconnect, connect, disconnect, … thing. Haven’t had a chance to investigate as yet but the case IO board’s USB-C cable was difficult to seat as its connector’s a little funky. So that’s the first suspect.
Similarly, my phone’s fine with an AMD laptop. Making it not an AMD, Ryzen, Threadripper, ASRock, or Linux specific issue.
It turns out I have two bad usb devices that both happened to go bad at about the same time. It wasn’t the cables, and isn’t the chipset. Very weird
