USB Problems :(
I recently switched over from a ASUS Z97 AR to an ASRock H97M-ITX/ac board. When I moved boards I took my OS with it. Now I can only use USB devices when I boot with them and. OS is Windows 8.1 Pro.
Have you installed the drivers for the USB controller on the new board, take a look in device manager to see if there is anything indicating problems there?
OS still thinks the drive is installed when I remove a flash drive.
Maybe try uninstalling the USB controller and re-installing with latest drivers from ASRock.
Intel only has the controller driver for 7
Did the MOBO come with a disc?
yep but the driver for the controller is 7 only
Okay then, just had a quick look and all I could find on their website was ones for Windows 7 aswell.
Is there any BIOS update available?
I did rest the bios and I dont know about update
And I have been scanning the controller for hardware changes it just gose on and on same with looking for updates
Maybe give the ASRock App Shop a go. Haven't used it myself but apparently it will scan your system for any available driver/bios updates.
http://www.asrock.com/feature/appshop/
still has not fixed the issue
Is your USB drive formatted correctly? I cant remember what it is exactly.
Also ensure that the drive has been allocated a drive letter
Can you remove the USB drivers in device manager so they reinstall?
