USB Ports Eventually Die?
Hi. Please help. Am I the only one facing this problem, if yes then what could be the reason? I have some USB3.0 ports on my PC (H67 Intel MB).. I usually connect external USB3.0 portable HDDs (without an external power chord, it's powered by USB port itself) to it... I had two ports on my PC, and for a long time I was using just one which started becoming very slow to recognize the drive and eventually it stopped recognizing the drive altogether... at first naturally I thought maybe the drive is faulty but when I connected to the another USB3.0 port (which I wasn't using), The Drive was recognized and it was very fast to show up as if I was connecting it for the first time. So, I started using that USB3.0 port.. and it stayed healthy for about 2 months and had the same fate (first became slow and then stopped working)... Then, I was using one of the remaining USB2.0 ports AND now this one also stopped working. I am clueless about what's happening. And it's not just one drive.. I have about 5 different 1TB external hard drives (without external power) where I store my documents. I have uninstalled and re-installed the USB drivers from Device Manager and tried all the software tricks... Is it something to do with hardware? Can it be that the USB ports on motherboard aren't giving enough power and dying out over time? What can be the problem and how can I prevent it from happening since I'll be getting a new motherboard now? Can getting a external powered USB ports hub which draws power from the socket rather than the motherboard solve the issue? Is there any such usb3.0 powered hub? Thanks!
I still have working motherboards with USB 1.1 so no. Just a faulty motherboard port, or the cable.
