I’m looking at getting a dork and usb monitor for my thinkpad X230T. I have the dock picked out, 10 bucks and I get 4 more usb ports, serial, vga, and displayport, plus a cd drive, but the usb monitor I’m trying to work out still.
Does it matter? I just want one to put drawing references on. At the place I can get a dock for 10 bucks, I can get a lenovo usb monitor for 60 bucks and an hp one for 112. It won’t be used for games, or anything more complex than still images and a youtube video or terminal.
Are there better ones than what lenovo puts out? Or hp? Or do I just do the lenovo one and call it good?
the USB interface shouldn’t be a problem if you’re using it for non gaming purposes. I used to have my PSP as a second monitor, and it was great for youtube videos and light web browsing, so I’m sure pretty much anything with a decent resolution would suit your needs. and for $60? Id call that a steal.
sorry for thread hijack the usb monitor market from current inspection is extreme hit or miss on everything if going for no names. there are a few good expetions can’t remeber the models/brand uses usb 3.1 gen 2 to attempt a 75hz but i don’t think that matters much. so jumping on, @mutation666 is refrencing? is fine just make sure its warranty is good imo over others
The OP has requested several times to keep his thread on track. Please make a new thread or converse in PMs if you wish to discuss the PSP further, as it was only brought up in passing about it being used as a second monitor.
