Hi All,
Looking for something quite specific, hopefully it can be done. I work in an office with basic Optiplex workstations and crappy 1280x1024 monitors. This is a pain as I typically have 5+ applications open that Im regularly using. Spend all day hitting Alt-Tab. The company only provide dual display setups to staff in the role above me which Im still working towards a promotion to. The workstations arent capable of dual display, needs a GPU to be added, so I cant just lug in a regular monitor.
So, a USB monitor would be perfect. Looking at AOC 16"s. I know draw rates arent great, but its just for a ticketing system/outlook so that wont be a problem. What is a problem is the software/drivers. Its part of a large enterprise domain and I dont have perms to install anything. The internal support guys arent super helpful either. This means I need something thats plug and play, no "DisplayLink" app/similar. Is there such a thing? Does windows pull generic drivers for USB monitors?
Googling hasnt thrown up much hard info so hopefully somebody here has some experience with this.
Thanks,
Linef4ult
