Usb Mice - Can't get them to work properly
Hi everyone,
For far to long I have had some kind of issue with my mice every mouse I try with my pc doesn't feel 100% correct like a mouse should, it's not that the mice don't work at all it's just that when you try any mouse on my pc compared to anyone elses pc; it feels completely different on mine with any mouse and any set-up. The problem seems to be that they just don't track perfectly, it makes the mice feel floaty and as if they don't track by PPI (pixels per inch). This counts for both Windows (7 64bit) itself and any video game.
Now I have created a list of all of the things I have tried to eliminate this problem, I am hoping that you guys may be able to work out what I have missed.
Flashed BIOS
Reinstalled Windows 7
Tried 4-5 Different Mice
Tried 3 Different Mouse Pads
Changed DPI
Changed Polling Rates on Mice
Used MarkC Mouse Fix
Mouse Acceleration is off / enhance pointer precision
Mouse Smoothing is off
Tried various video card drivers
Installed Mouse Drivers
Tried different resolutions
Tried vSync on and off
Used different USB Ports
Feels the same on desktop and in any game
That may not be everything, but as you can see I have tried a lot of things.
Any help will be fantastic as I have had this issue for too long. I can add more details if you request it.
Many Thanks,
Luke
